Camshaft or Heads??
Old 08-28-2009, 12:22 AM
92 5.0stang
92 5.0stang's Avatar
Default Camshaft or Heads??
I only have enough money to do one of them , which would be the best to get first or can you even do that? Which ever you think is better to get please tell me what i need to buy with each. Also is a camshaft easy to install? I will be doing this with a experienced person i just want to know. Im not looking to take my car to the strip its just a street car, i have basic mods , headers, air intake, offroad x pipes, flowmasters, and bbk intake manifold , UPR undrive pulleys
92 5.0stang is offline
Old 08-28-2009, 12:38 AM
westcoast25
westcoast25's Avatar
What kind of heads are you talking about? A good set of heads are way more than a cam...
westcoast25 is offline
Old 08-28-2009, 12:47 AM
92 5.0stang
I was gonna get some AFR 185Cc , i know that heads are more i have enough for just the heads or the camshaft and some other things not both
Old 08-28-2009, 12:51 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
Well first off like already said the price range with the 2 are completely different usually. I would look into getting some subframe connectors for that vert though. Your car will handle ALOT better, even just on street duty.
You replied before I did on it. You can get away with a set of heads and not upgrading the cam yet but for just a little extra that cam will make your motor come ALIVE! If you get the right one at least.
projectresto83 is offline
Old 08-28-2009, 01:04 AM
92 5.0stang
ya i have about 1600 to do it with . so what else do i need to get when i buy the heads . the ones im looking at are AFR185. is it better to get stud or pedestal mount
Old 08-28-2009, 01:07 AM
primetime5.0
primetime5.0's Avatar
lol your going to spend over 1600
primetime5.0 is offline
Old 08-28-2009, 01:12 AM
92 5.0stang
ya i figured that when i saw the prices of the heads i wanted, im still putting away more money just for that reason , im not doing it just yet because of that reason but i just want to get an idea of what i needed to get
Old 08-28-2009, 01:55 AM
luckythirteen13
luckythirteen13's Avatar
do the heads, a cam with the stock heads is pointless.
your going to need the heads, head gaskets, intake gaskets, header gaskets, and head studs or bolts
luckythirteen13 is offline
Old 08-28-2009, 02:51 AM
5.0stang123
5.0stang123's Avatar
Just save up and do h/c/i all together as a package, that way you can match everything up and it will save you hassle and wasted money.
5.0stang123 is offline
Old 08-28-2009, 06:56 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
no point in doing a cam as you'll have to swap springs on the heads to match cam requirements, best to save a little more so you can do both at once
mjr46 is offline
Quick Reply: Camshaft or Heads??
