R&R rear end housing bushings
Old 08-30-2009, 04:46 PM
92hatchLX
92hatchLX's Avatar
Default R&R rear end housing bushings
Hey guys I picked up a set of Moog rear end housing bushings because mine are crap (these are the bushings that go into your rear end, the upper control arms mount to them). Has anyone done these without the tool. What's the easiest way to do them? I sprayed them down with some PB blaster and I'm putting the new bushings in the freezer.
92hatchLX is offline
Old 08-30-2009, 05:32 PM
turbosha
turbosha's Avatar
good luck!!!.ive done em with the axle out. and a big pain in the butt. ended up torching them out.almost impossible to do in the car.maybe dissconnent the shocks and brake line and lower as far as possible.
turbosha is offline
Old 08-30-2009, 06:41 PM
92hatchLX
92hatchLX's Avatar
Uh-oh hit a snag. I thought I got the right kit but I'm having doubts now. One of the bushings is about 1/4-1/2 an inch larger that the other. Are the two bushings in the rear end different sizes or did I order the wrong thing?
http://www.summitracing.com/parts/MOG-K8637/
Old 08-30-2009, 07:20 PM
turbosha
turbosha's Avatar
should buy this kit
http://www.summitracing.com/parts/FMS-M-4050-B/
turbosha is offline
turbosha
turbosha's Avatar
the two bushings are supposed to be identical
turbosha is offline
Old 08-30-2009, 07:29 PM
92hatchLX
92hatchLX's Avatar
That's what I figured. I bought these from work so I'll just return them and order the ones from Summit or see if we can figure out which ones I need. I like using Moog stuff.
Old 08-30-2009, 08:51 PM
primetime5.0
primetime5.0's Avatar
MM sells oem ford ones for cheap
primetime5.0 is offline
Old 08-30-2009, 09:29 PM
92hatchLX
92hatchLX's Avatar
I was looking at those on the MM website. I can get the Moog stuff way cheaper than those. I get them at cost and don't have to pay for shipping.
Old 08-30-2009, 09:34 PM
primetime5.0
but you know the oem ford ones are the correct ones
Old 08-30-2009, 09:40 PM
92hatchLX
92hatchLX's Avatar
True, I got the Ford part number off of the MM website. I'll see tomorrow if I can cross some numbers and see if I can get the correct kit. If not I'll have our parts runner stop by the dealer and price some out for me.
Nick Oliver
10-17-2018 04:22 AM
musnicki
09-23-2015 07:11 AM
Roush05
09-10-2015 12:23 PM
Dragonus18
09-09-2015 01:21 AM
cbird1177711
09-02-2015 08:51 PM
Quick Reply: R&R rear end housing bushings
