i know i need a throttle body but which one should i get. i have a 302 with cast iron gt40 heads and the explorer intake. the opening for the intake is 65 but i still have the stock 60mil. i herd you can run up to a 75mm with out changing anything but i need to know for sure before i buy it. will a 70 or 75 bolt on to a 65 egr spacer? help please!
You need to match them.... if you don't want/decide/choose to upgrade the EGR spacer, use the same ID TB. If you decide/choose to upgrade the EGR spacer..... a 75mm or 70mm will keep you busy. LUK
......your about to open up a can of worms with that statement
lol....If you get a bigger throttle body you need a bigger intake,if you get a bigger intake you need bigger heads, if you bigger heads you need a supercharger to jamb it all in there.
Ahhh just go for the crate motor,lol j/k
that's not the can of worms I was refering to, FYI there is no such thing as to big a throttle body if proper matching and tuning is done to compensate for changes made. research it a little and you'll understand what I mean
I think I'm in the same boat ur in. I ordered a 70mm tb with egr spacer tuesday should be at the house when I get there and yes it will be installed this weekend. When all is done I'll post back with if it worked or not.
