front frame rail rebuild
Old 09-08-2009, 09:27 PM
351roller
351roller's Avatar
Default front frame rail rebuild
I have an 85 hatch that is totally gutted and should have been in the junkyard,but after both rocker panels both floorboards four big holes in the roof ,last 12" of rear frame rails two quarter panels , replaced the whole cowl section, and numerous other rust outs I am at the last area which is the totally gone front frame rails. My original plan was to start building the rail with .089 plate, but I also have enough .080 2x4 tubing left over from the weld in sub frame connectors that I put in to use it also. I guess my question is has anyone out there replaced the frame rails and what they used.
thanks
351roller is offline
Old 09-08-2009, 09:37 PM
fastang85gt
fastang85gt's Avatar
i replaced my driverside rail in my 85 with a rail from the junkyard
fastang85gt is offline
Old 09-08-2009, 09:39 PM
AdderMk2
Banned
AdderMk2's Avatar
sounds like an incredible waste of time to me
AdderMk2 is offline
Old 09-08-2009, 09:44 PM
86 5.0L
86 5.0L's Avatar
Originally Posted by AdderMk2
sounds like an incredible learning experience to me
fixed
I would do it, sounds like funny
86 5.0L is offline
Old 09-08-2009, 09:51 PM
AdderMk2
Banned
AdderMk2's Avatar
Originally Posted by 86 5.0L
fixed
redoing metal work on a 60s to early 70's stang.. fun
fixing a fox... waste of time
AdderMk2 is offline
Old 09-08-2009, 10:11 PM
CoDell85GT
CoDell85GT's Avatar
All I can say is wow I hope you guys Know each other!
If it helps I just got done reading through this thread
Theres a nice write up of his frame rails being redone.
I may be headed down this path? Once I have the motor out I'll know for sure.
Good luck with the rebuild!
CoDell85GT is offline
Old 09-08-2009, 10:12 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
sell it buy a car like this blk 4 eye :P
http://www.jaxracing.com/forum/showthread.php?t=44809
i wish i had 1200$ 4eye +351c+built auto= tons of fun
rmodel65 is offline
Old 09-09-2009, 08:06 PM
351roller
351roller's Avatar
This car was a bad move on my part ,but after all we have been through I cannot give up on it like so many people that have no mechanical abilities. Was looking for responses from people that can fabricate. Have strengthened everything from back to front and want to strengthen front also beyond stock without a tube frame.
Old 09-09-2009, 08:31 PM
SonicBlueFiveSlow
SonicBlueFiveSlow's Avatar
I'm sure Kyle will chime in on this thread sooner or later.
SonicBlueFiveSlow is offline
Old 09-09-2009, 08:52 PM
stang8689
stang8689's Avatar
yeah it sounds like you coulda started out alot better but if you did that much work then good luck
stang8689 is offline
Quick Reply: front frame rail rebuild
