engine POPPING!!!!
Old 09-17-2009, 12:58 AM
mustang90242
mustang90242's Avatar
Exclamation engine POPPING!!!!
recently my car has been making a popping sound. i was told it was the wires so i changed the wires. does anyone have any solutions. it pops when i accelerating
mustang90242 is offline
mustang90242
i changed the spark plugs 2 months ago
Old 09-17-2009, 01:01 AM
Dj_Seph
Dj_Seph's Avatar
Your distributor is possibly off a few teeth. Check your timing.
Dj_Seph is offline
Old 09-17-2009, 01:04 AM
mustang90242
should i increase the timing? its set at 8
Old 09-17-2009, 01:11 AM
socalwrench
socalwrench's Avatar
He is referring to the valve timing. If the chain has moved than your cam and valvetrain timing has changed.
You are referring to the ignition timing. This is changed by rotating the distributor.
A popping sound isn't very distinct. Since the car isn't in front of me, that could be a backfire from the exhaust or a misfire from the engine. If either timing is off, it could cause the misfire.
socalwrench is offline
Old 09-17-2009, 01:12 AM
luckythirteen13
luckythirteen13's Avatar
stock is 10
luckythirteen13 is offline
Old 09-17-2009, 01:18 AM
mustang90242
its a misfire forsure because it pops hard like a littler hitting the engine. so what do you recommend me doing? and how much will be the average price for repair?
Old 09-17-2009, 01:20 AM
mustang90242
i meant to put little hammer hitting the engine
Old 09-17-2009, 12:55 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
can you get a video?
projectresto83 is offline
Old 09-17-2009, 01:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
when is the last time it had a full tune up?? ie...cap, rotor, plugs and wires??
mjr46 is offline
Quick Reply: engine POPPING!!!!
