Rear end help!!!!!
Old 10-02-2009, 10:24 PM
1slick88cat
1slick88cat's Avatar
Default Rear end help!!!!!
What is a good differental for my rear it's a 8.8 don't have a clue between lockers, limited slip, posi and so on could someone explain them to me thanks in advance
1slick88cat is offline
Old 10-03-2009, 08:15 AM
JDraper
JDraper's Avatar
Need to know what you plan on using the car for first. For drag racing, you're going to want a different rear end than for road racing, and that is again different from a daily driver that doesn't see the track at all.
A locker solidly locks the rear axleshafts together so they both see power 100% of the time. There are various types. Some are "lunchbox" lockers that work automatically and some are controlled lockers that you can switch on and off. When a locker is engaged, the car will bind slightly in corners as one wheel can't turn faster than the other. Lunchbox lockers are cheaper and easier to install, but aren't as good as a full locker. You don't need to re-set the gears with a lunchbox locker because they fit inside of your existing differential case, but you do with a full locker that replaces the differential case.
A limited slip rear generally uses clutches to supply power to both wheels while still allowing the outer wheel to turn faster than the inner wheel in a corner.
The term "Posi" is thrown around to describe both a locker and a limited slip rear. It stands for "Positive Traction", meaning both wheels are powered, unlike an open differential.
JDraper is offline
Old 10-03-2009, 09:47 AM
mu$tang95
mu$tang95's Avatar
JDraper: That's a really good explanation, I never knew the difference, I have 3:73s in my 8.8 95 GT with a ford racing limited slip diff, and I could notice a big difference in the handeling of the car.
mu$tang95 is offline
mtgldr
02-03-2024 09:00 PM
zsmart
Convertible Tech
02-29-2016 08:33 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
fastbackford351
09-12-2015 09:42 AM
Dragonus18
09-09-2015 01:21 AM
Quick Reply: Rear end help!!!!!
