posi traction
Old 10-04-2009, 07:46 PM
nitrous_fed_03gt
nitrous_fed_03gt's Avatar
Default posi traction
when i bought my 88 lx a few months back, the guy claimed he put a 373 gear in when he converted the back brakes to discs. i have no idea if this is true or not but i do know the car is just a one tire fire. what do i need to do to convert it to positive traction? thanks
nitrous_fed_03gt is offline
Old 10-04-2009, 07:59 PM
socalwrench
socalwrench's Avatar
Well, it's easy to tell the difference between disc and drum brakes. They don't look anything like each other.
BASIC DISC
BASIC DRUM
First off, I dislike the posi-traction name. That's a manufacturer specific name and part type for a limited slip differential. Unless you're a GM guy- let's move on.
Second, adding a limited slip differential, or LSD, isn't very difficult on your FOX. It should have a 8.8" rear axle. As far as converting it- you'll need a LSD for your ratio (usually fits a range of gear ratios), gear oil, friction modifier (depending on the type of LSD), a shim kit and crush sleeve (possibly- depending on the pinion depth). A good shop should have the last two parts. If you're doing it yourself, you'll also need the dial gauges for setting up the runout and backlash measurements.
Lastly, while it's not a necessity, I would also recommend a rear cover girdle. It simply replaces the stock cover and applies pressure to the diff. bearing caps.
socalwrench is offline
Old 10-04-2009, 10:05 PM
Sidewayz6.0
Super Moderator
Sidewayz6.0's Avatar
Wow. First of all, the OP didn't ask the difference between drum and disk brakes. He said he didn't know if the car actually had a 3.73 in it or not.
Second, while I can tell you're one of those Ford fanboys, Posi-Traction is a pretty universal generic term (and certainly the most commonly used) for a Limited Slip Differential. Since we're being all technical here, Ford calls it Trac Lok. Packard actually came up with the term LSD.
You actually don't like it when someone says Posi-Traction?
As for the rear end not having LSD? Was this a 4-Cyl swap car? Is it possible that the car still has a 7.5"? No V8 Foxes came with an open gear. The 8.8's are all Limited Slip. If it's got an 8.8 and one tire fire syndrome, the clutches are more than likely worn out, and in that case, you're only looking at about $100 for a rebuild kit. If you can do it yourself.
For the 3.73, jack the back of the car out. Rotate the rear tire and count how many times the driveshaft spins completely around with one revolution of the tire. If it's a 3.73, it will be just less than 4 revolutions of the driveshaft.
Good luck to you.
Sidewayz6.0 is offline
Old 10-04-2009, 10:14 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
bbwaaaahaaaaaaa ....owend!!!!!!!!!!^^^^^^^
mjr46 is offline
Old 10-05-2009, 01:01 AM
luckythirteen13
luckythirteen13's Avatar
sidewayz is correct, if you have an 8.8 rear end (all foxes with v8 stock had them), your track lock is worn out. if i recall tho, the rebuild kits are $55 unless they have gone up in price
luckythirteen13 is offline
Old 10-05-2009, 01:53 AM
Bobert
Bobert's Avatar
Not trying to high jack the thread
but i have a 5.0 ( obviously ) and its got the 8.8 i am 99.99% sure its original
i hard er jacked up like 2 years ago. and did the good ole rotate the one wheel and see if i got a posi! ( im been a chevy guy since i was a kid deal with it )
and oh snap the other wheel went the same way yay!
every burnout i have ever done has only thrown down rubber on the left side ( i think )
even in the grass on a slope i was spinning but only the left...
is this the clutches and should i rebuild?
doing it myself is no problem
done pirating thread
Bobert is offline
Old 10-05-2009, 04:28 AM
boonedj
boonedj's Avatar
i could be wrong but its gota be the clutches because my 93 has the original 8.8 and i spin both tires all day when i light em up
boonedj is offline
Old 10-05-2009, 06:13 AM
Back-in-Black
Back-in-Black's Avatar
Both tires should spin. You need to rebuild. I would bet the clutches are worn but only show the problem under load.
Back-in-Black is offline
Old 10-05-2009, 07:38 AM
guitarist4life
guitarist4life's Avatar
ill hijack it too! ha
Im having the same issue as the other hijacker. I got a 89 gt 5.0 vert automatic. When i stop on it only the left burns rubber. SOOO im thinking i need a rebuild as well. Ill buy the kit but have a shop do it cause I lack those particular skills needed. Estimate? Thanks
guitarist4life is offline
Old 10-05-2009, 08:07 AM
Cleeman99
Cleeman99's Avatar
nitrous fed o3 gt pm me your vin number and ill run it on car fax see if it a real 5.0l or whether its a swap. lol i bought the unlimited 30 day reports and ment to buy a one time single report lol so you can if you want i wont charge you nothing but being the age nothing may show up.
Cleeman99 is offline
Quick Reply: posi traction
