bogs down when floored...
Old 10-23-2009, 02:52 PM
  #21
nacanitihs
nacanitihs's Avatar
^^^ buy a timing pointer
nacanitihs is offline
Old 10-23-2009, 06:34 PM
  #22
zebo87
zebo87's Avatar
for the whistling sound check your iac. it might need to be cleaned. with a surging check for vac leaks with some starting fluid by spraying it around your heads and intake. i am having the same issue and my coil is good as well. one thing i havent checked is my tfi module yet. mine runs rich n also. im used to it due to no cats but it runs richer than usual. if i can bypass the tfi plug then i will let you know the results.
zebo87 is offline
Old 10-23-2009, 11:34 PM
  #23
9165pt0
9165pt0's Avatar
i swapped coils again today. and the car did feel a lil stronger. i also cleaned iac and its not making the whistle. the whistle gets extremely loud right near the top of upper intake
9165pt0 is offline
Old 10-24-2009, 10:07 AM
  #24
zebo87
zebo87's Avatar
thats almost gotta be a vacuum leak with that whistling.
zebo87 is offline
6bangr
02-15-2016 07:40 AM
Seanam
10-04-2015 10:15 AM
Daddys Girls GTs
09-14-2015 08:46 PM
nickpeck28
07-05-2004 10:45 PM
Meaty84Stang
05-05-2003 02:10 AM
Quick Reply: bogs down when floored...
