Alphabet cams
Old 10-14-2009, 07:22 PM
mattdel
mattdel's Avatar
Default Alphabet cams
I've been looking at some idle videos of exhaust with various mods and I'm hearing a distinct similarity between what my car sounded like when it was running and an E cam.
Given that I am not a machinist, I obviously havn't got the proper tools to measure my lobes and find out.
Are there any distinct markings on the alphabet cams that distinguish them from stock? Also, if I were to use a micrometer from the bottom of the base circle to the top of the lobe, are there any spec sheets I could compare to?
mattdel is offline
Old 10-14-2009, 07:25 PM
nacanitihs
nacanitihs's Avatar
should say it on the front of the cam. mine said f303 on it
nacanitihs is offline
Old 10-14-2009, 07:28 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
Matt, on the heel of the cam it'll be clearly stamped
mjr46 is offline
Old 10-14-2009, 07:34 PM
loeryder21
loeryder21's Avatar
my E303 had it stamped too
you should be able to measure a difference in the lobe, that is how you determine how much lift the cam would have
loeryder21 is offline
Old 10-14-2009, 07:38 PM
mattdel
mattdel's Avatar
just went out and looked at the motor i purchased, all it has is two B's and 1D1, so I'll assume that stock. I'll take the other one out tomorrow and have a peek.
mattdel is offline
GimpyHSHS
19
12-19-2023 01:12 PM
patchshaffer
Tuner Central
10-05-2015 02:24 PM
uedlose
The Racers Bench
10-01-2015 08:31 PM
junior04
09-28-2015 10:53 AM
Ryan Fitzpatrick
09-14-2015 02:21 AM
Quick Reply: Alphabet cams
