head Gaskets
Old 10-24-2009, 06:40 PM
30coupe1
30coupe1's Avatar
Default head Gaskets
I have an 89 5.0 that i put a supercharger on. I had it tuned, and ran it for a while, i had the milkshake looking oil so i changed the head gaskets and intake gaskets. When i did this i also did an a/c delete. Now it seems like it runs 200 rpm faster than it did before. Does the a/c mean that much? I guess im going to try and get a retune.
30coupe1 is offline
Old 10-24-2009, 07:17 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Removing the a/c should have nothing to do w/ idle speed.
PRO50SC is offline
Old 10-24-2009, 07:20 PM
30coupe1
30coupe1's Avatar
What do you recomend that i do with my distributor? I think i got it to tdc on #1 and i had a mark for where my distributor came, but it still doesnt run the same.
30coupe1 is offline
Old 10-24-2009, 07:25 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
You need to be more specific about the problem. First you say it idles 200 rpms higher, now you say it doesn't run the same. If it's just the idle, try adjusting the mechanical adjustment screw on the t/b. What rpm does it idle at?
PRO50SC is offline
Old 10-24-2009, 08:12 PM
30coupe1
30coupe1's Avatar
It idles at 1100 right now and used to idle at 900. I hope i didnt throw my tune off. It actually doesnt run too bad though. if i do turn my distributor it doesnt change the idle. I wonder if i really messed up my timing/ afr
30coupe1 is offline
Old 10-24-2009, 09:09 PM
zebo87
zebo87's Avatar
have you checked for vacuum leaks. with removing the intake those gaskets can get tricky.
zebo87 is offline
Old 10-24-2009, 09:36 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
perform a base idle reset
mjr46 is offline
Old 10-24-2009, 10:11 PM
AdderMk2
Banned
AdderMk2's Avatar
oh dear god man...
set your distributor timing (with a timing light) to 10° BTDC
allow car to relearn KAM by driving GENTLY for a hundred miles or so..
AdderMk2 is offline
Old 10-24-2009, 11:25 PM
30coupe1
30coupe1's Avatar
What is a base idle reset? I dont know what the timing was before it was tuned. The car had nitrous before and i guess the timing must have been retarded. Should i still go to 10 degrees btdc?
30coupe1 is offline
Old 10-24-2009, 11:35 PM
AdderMk2
Banned
AdderMk2's Avatar
most tuners set distributor timing to 10 and set everything else in the ECM
and http://www.google.com/#hl=en&source=...c9ea851cee2c5b
google seriously helps
AdderMk2 is offline
Quick Reply: head Gaskets
