Adjustable crane cam rocker arm problems
Old 11-02-2009, 10:57 AM
ballajb
ballajb's Avatar
Default Adjustable crane cam rocker arm problems
Ok i am having a problem. I started my car and noticed a ticking noise under the valve cover. So i took it off and noticed that 2 of my rockers had came off/loosened. I tried tightening them and started the car and the same 2 did the same thing again. I am wonderin what could this be? Why are they coming a loose? i am using the locks and everything. Could it be that i need to clean them off and let them dry before i try again? could it be that the oil that are in the grooves now from the nut and lock coming off?
Has anyone else ever had this problem? if so how did you fix it?
ballajb is offline
Old 11-03-2009, 05:53 PM
FLcracker9
FLcracker9's Avatar
This shouldn't be happening. You are adjusting the nut, and then tightening the allen head set screw correct?
FLcracker9 is offline
Old 11-04-2009, 09:59 AM
ballajb
ballajb's Avatar
Ok, so i checked again yesterday and what i found is a lot of my studs were not as tight as they could be. So i basically tighted all of them and reset all the rockers... Put everything back on and its fine... Finally after taking things apart a couple of times. Now just to figure out how to stop this whistling noise from my throttle body....
Thanks for the help everyone
ballajb is offline
copestang
10-11-2015 07:17 AM
Dragonus18
09-09-2015 01:21 AM
raleigh05GTO
09-04-2015 07:09 AM
Luke9222
09-04-2015 06:46 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: Adjustable crane cam rocker arm problems
