Brake problems
Old 11-15-2009, 05:59 PM
r1sky5.0
r1sky5.0's Avatar
Question Brake problems
I just bought a 85 mustang 5.0 and i noticed the brake pedal goes all the way to the bottom and it berly wants to stop. What can be the problem? I got the car for cheap so I still dont regret buying it. Any help is appreciated.
r1sky5.0 is offline
Old 11-15-2009, 06:08 PM
fordboy5.0
fordboy5.0's Avatar
have you tried bleeding them?
fordboy5.0 is offline
Old 11-15-2009, 06:10 PM
PRO50SC
The Rogue Mod
PRO50SC's Avatar
Have you looks for leaks? It's not rocket science.
PRO50SC is offline
Old 11-15-2009, 06:19 PM
r1sky5.0
r1sky5.0's Avatar
Ive looked for leaks all over the car. I was going to bleed them but I heard it might be the brake cylinder?
r1sky5.0 is offline
Old 11-15-2009, 06:27 PM
mattdel
mattdel's Avatar
misadjusted rear brakes will cause this, and is the easiest to check/fix.
mattdel is offline
Old 11-15-2009, 06:30 PM
fordboy5.0
fordboy5.0's Avatar
i would try bleedin them first, its allot cheaper than a brake cylinder and its a good way to check before you go spendin your money
Old 11-15-2009, 06:38 PM
r1sky5.0
r1sky5.0's Avatar
i will try bit suggestions and will report back when done.
r1sky5.0 is offline
Old 11-16-2009, 11:44 PM
r1sky5.0
r1sky5.0's Avatar
What would cause the brake pedal to sinl all the way down? Would it be the brake master cylinder or the brake booster? We took the car on a test drive and it had no brakes what so ever.
r1sky5.0 is offline
Old 11-17-2009, 02:07 AM
nba1341
nba1341's Avatar
air in the brake lines would cause this
would also cause the car to have no breaks whatsoever
nba1341 is offline
Old 11-17-2009, 08:37 AM
mattdel
mattdel's Avatar
I don't understand why everyone here is so sure he has air in the lines. If he didn't take them apart recently and has no leaks, the chance of having air in the lines is almost 0%.
Also, as far as the pedal goes... when it sinks all the way down, is there a bit of pressure in the pedal as it goes down, but doesn't seem to do anything, OR does it just drop to the floor with no resistance whatsoever?
The answer to that question is vital in determining between various problems you could have.
mattdel is offline
Quick Reply: Brake problems
