I might be off by a tooth or two...
on my distributor. Reason being is that the car takes several tries to start before it catches, sometimes letting out a small intake backfire in the process. It'll start a little rough, but then It'll run fine once the idle settles, driveability isn't really affected after that. How can i check if im off a tooth? i think my timing is set at 14*
i primed the pump 5 times before turning it on. it caught the first time, but pretty weak. this may have something to do with other problems ive been having. does this sound like a weak pump to you all? FPG comes today, so i'll know for sure about the pressure when the car gets warmed up/hot.
how many miles are on the car? it might be time for a new chain, when you install the chain it wouldnt hurt to pull the distributor too to check its gear... just get #1 cylinder at TDC the stab the dizz so the rotor lands on the #1 plug wire, once you start it adjust the timing...
but it may be a fuel pressure issue also, if the reg is not new, change it, you have to pull the upper intake for that, otherwise its a pain
the car is well in its 200k range. The issue, however, started after i changed the stator in the distributor. So i could have very well put it back in wrong, but not wrong enough to make the car fail. I had marked everything and when i put it back i thought it was correct.
I have the FPG here with me, but im scrounging around to find the necessary fittings. the autoparts store has it on special order only, so it'll be a day or two before i can check the fuel pressure.
rgormansouth
08-24-2013 11:10 AM
