>broken alternator bolt...ouch<
the lower alternator bolt holding it into my head broken clean off... more than half the thread is still stuck in the head. ive been thinkin of options and came up with two possibilities---
1. suck it up and drill it out.
or
2. see if there was a way to remount the alternator somewhere else on the motor. in the second picture is where i thought i saw an opportunity
what would yall do. this is my daily driver too. its got a 331 stroker with gt 40 heads
or
Center punch first then use new De Walt cobalt drill bit. Pb Blaster- spray to keep bit cool while drilling. Try an easy out. Don't extract, keep on drilling then rethread. This all seems painful but will soon pass. Put anti-seize on replacement bolt.
did this not too long ago.
go buy a drill bit and easy out. the bolt can only thread 3/4" into the head. drill a small hole in the bolt then use the easy out. you need to apply pressure to the easy out to force it in the hole. and dont put it on the drill. you gotta do it manually. vice grips or something.
