idle all over the place.
Well here in the west coast were getting rained on hard.. I had to drive my car through some water on my way home... I felt my car bogg alittle bit but thought it was the water effect.. now my idling is crazy and also my de-acceleration takes for everrrr...
idk what it iss... maybee my maf is malfunctioning?... idk..
Help please!!
thanks
Help please!!
thanks
Take alook at the ignition components. If there wet, its going to cause a running problem. Most autoparts stores sells a wrie dry. I would do a visual inspection of the engine bay. And pull the codes if the CEL is on as stated by the other poster.
if your car has a CAI and the filter is in the fender, it could of sucked up some water and contaminated the MAF, as the water enters the filter it can carry oil that is used to lubricate the filter and thus contaminate the maf sensor, clean the maf if such be the case and air dry filter
know how you feel, my neighborhood flooded. luckily i have a f150 on 37s for situations like this.
like others have said, clean the maf, check for codes and then go from there
