?questions about the tranny??
Old 01-22-2010, 01:32 AM
1990fox5.0
1990fox5.0's Avatar
Exclamation ?questions about the tranny??
i have a 1990 5.0 with the 5speed, latley its been hard to get the shifter into gear, just the last half an inch is hard. and i have to force it in there to get it. i was wondering if anyone knew what it could be, and whats the best tranny fluid for this prob. and how much does it take to fill a empty tranny up. thanks for the help.
1990fox5.0 is offline
Old 01-22-2010, 02:10 PM
MustangBradley
MustangBradley's Avatar
Odds are your clutch is going. A dragging or a partially un-released clutch will make it hard to get into gear. Are you still on your stock clutch? Do you push your clutch hard?
MustangBradley is offline
Old 01-22-2010, 04:37 PM
rmodel65
Yukon Cornelius
rmodel65's Avatar
adjust your clutch cable... if you have the stock setup just pull up on the pedal to remove slack
rmodel65 is offline
Old 01-25-2010, 03:49 AM
1990fox5.0
1990fox5.0's Avatar
i do have the stock setup, u want me to just pull up on the pedal.
Old 01-25-2010, 12:25 PM
paintballjerry
paintballjerry's Avatar
With the car off, put the clutch to the floor and release it. Reach down and grab the pedal and pull it firmly straight up. You should feel it if you have any slack. You may have to do it twice.
paintballjerry is offline
Old 01-25-2010, 01:52 PM
1990fox5.0
1990fox5.0's Avatar
alright i tried it it helped alittle, thanks for the help guys
Old 01-25-2010, 02:14 PM
paintballjerry
Then you may have to replace the clutch like the others said. Besides, it gives you a reason to put that Kevlar clutch in!!!!
chrisdbassplayer
10-13-2015 06:53 PM
UrS4
09-30-2015 10:13 AM
treesloth
09-28-2015 07:03 AM
2poor4u2
09-26-2015 11:08 AM
Quick Reply: ?questions about the tranny??
