H-pipe if I have flows?
RE: H-pipe if I have flows?
ORIGINAL: justamemory3
Are there any sensors or anything you have to worry about when switching the pipes out? Thanks again.
you should have 2 oxygen sensors in the pipes. one on the passenger side, one on the driver's side. i would unplug them at the harness connector, and just pull the pipe out with them still attached. when you have the pipe out, wrench out the sensors and install them in the new pipe, and install pipe. then reconnect the harnesses. all done
sorry for all the questions, buti noticed that one of the bolts on the front passenger side is tucked way up there. how do i get to this one?
Luke9222
10-22-2015 11:55 PM
09-24-2015 09:18 PM
09-10-2015 08:39 PM
