need anwser about somthing
Old 03-14-2010, 01:16 PM
jdemario
jdemario's Avatar
Default need anwser about somthing
hey i was wondering since i got a 351w motor that i am building will the 302 fit on the 351 the motors are the same age
thanks
jdemario is offline
Old 03-14-2010, 01:24 PM
93hatch306
93hatch306's Avatar
will the 302 WHAT fit on the 351?
the heads will interchange, but intakes are different (the 351 is wider).
what parts do you want to try to use?
93hatch306 is offline
Old 03-15-2010, 12:50 AM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
WRONG, stock 302 heads will NOT fit a 351 EXCEPT GT40's and P's. 351W heads will fit a 302 though. The 351 uses bigger head bolts than the 302 does so the head bolts won't fit through a stock 302 head. BUT if you are talking about aftermarket heads then a 302 head will usually fit because they already have the head bolts machined out for the 351 because it can work on either or.
Like already said though. The intakes and oil pans are different because of the wider block. Are you trying to ask what you need to swap the 351 in the mustang????
projectresto83 is offline
elgato
05-26-2005 04:29 PM
88mustanglx
04-22-2005 11:22 PM
95stangr
02-23-2005 09:10 PM
DaGGer
02-07-2005 08:24 AM
souron
05-04-2004 05:42 PM
Quick Reply: need anwser about somthing
