tps gasket
Old 11-24-2003, 04:02 AM
af41
af41's Avatar
Default tps gasket
I was told that on some 5.0s you can take the two screws of the tps and remove the triangle shaped gasket. They also said if you replace the gasket with one that is cut for the whole plate it can give you "carb-like" response. Has anyone heard of this? I was told your car can backfire sometimes though.
af41 is offline
Old 11-24-2003, 11:57 AM
vfast
I ♥ Acer
vfast's Avatar
Default tps gasket
nope..
vfast is offline
Old 11-24-2003, 02:18 PM
Quik
Quik's Avatar
Default tps gasket
if the tps is improperly adjusted it can backfire from time to time
Quik is offline
10-26-2015 05:01 PM
Dathan
10-05-2015 05:52 AM
wraith777
09-28-2015 10:49 AM
Demodulates
09-18-2015 11:14 AM
EASTIDEE123
09-15-2015 11:08 AM
Quick Reply: tps gasket
