T5 rebuild
Old 03-26-2010, 01:50 PM
marlyman
marlyman's Avatar
Default T5 rebuild
So yeah im sure my T5 is coming to the end of its life and my motor is freshly rebuilt so now i guess its time to rebuild the tranny..now i haven't done it before but im sure it couldnt possibly be that hard...HaH really tho is it possible? i mean any handbooks around to help rebuild the 87-93 5speed manual transmissions? i know im goin to pull it out an open it up an just be lost with all the little pieces i rebuilt my 302 easy i mean i did get some help from u guys on this msg board but otherwise i did myself and im no certified mechanic but my motor definetly rips an purrs good .. i bored it out .30 ovr new main/rod bearings new crank cam pistons heads intake i did it all...an i just lookd up a rebuild kit for the t5 an looks like a lot of pieces..any hints or tips? thanks appreciate the help!!
marlyman is offline
Old 03-26-2010, 02:02 PM
marlyman
marlyman's Avatar
Also i was wondering what is / how important the synchros are? i've been looking for rebuild kits an most i've seen come without the synchros...any input is helpful thanks again!
marlyman is offline
Old 03-26-2010, 02:19 PM
wsimard
wsimard's Avatar
buy the kit with the syncronizers.make sure it has the keys and springs also.
wsimard is offline
Old 03-27-2010, 01:29 AM
94ford5liter
94ford5liter's Avatar
instead of bothering with rebuilding your T-5, you should just look around for a TR3550 or 3650. You can get them for under 1 grand on ebay and they are considerably stronger than a t-5.
94ford5liter is offline
Old 03-27-2010, 01:35 AM
joshs89gt
joshs89gt's Avatar
i'm pretty sure with most rebuild kits theres stuff you have to get pressed in, and have to take it to a machine shop or someone with a press. synchros are what meshes up each gear to match up to the gear your trying to get into. or something i think. the best price i could find on a rebuild is 700 in CO.
joshs89gt is offline
Old 03-29-2010, 09:38 AM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
Originally Posted by 94ford5liter
instead of bothering with rebuilding your T-5, you should just look around for a TR3550. You can get them for under 1 grand on ebay and they are considerably stronger than a t-5.
fixed it for you.
3650 and T45 are 4.6 trannies, the bell housing bolt pattern is different.
and T5's can b made very strong, im about $1500 into mine, will handle 550tq, has a .82 OD, and STILL weighs 75lbs as opposed to 100+ for the other options.
and you can beat the bolt in simplicity of a T5 either.
OP, check out astroperfromance.com, ask for Tony, he'll help you out.
sn95_331_GT_ yellow is offline
Old 03-29-2010, 04:51 PM
jssblues
jssblues's Avatar
whose got 1 grand laying around for a tranny...damn i guess the economy isnt so bad after all
i think you can get that thing rebuilt for like 300$$$
jssblues is offline
Old 03-29-2010, 05:25 PM
minnow81469
minnow81469's Avatar
Originally Posted by sn95_331_GT_ yellow
fixed it for you.
why spend that on a t-5 hahaha i would have spent that money into a tko 600 more bucks for a better piece of mind and a better tranny
minnow81469 is offline
Old 03-30-2010, 12:06 PM
5pt0driven78
5pt0driven78's Avatar
Talking
I'm planning on rebuilding my T5 in the next couple of weeks. I've done a little research and you don't really need any specialty tools. You can buy the Ford Racing 94-piece rebuild kit from jegs for just $326. Here's the link for the T5 complete service manual http://www.ttcautomotive.com/English...0-0199_173.pdf which shows how to take apart and put back together. Good luck either way!
5pt0driven78 is offline
Old 03-30-2010, 12:28 PM
1990lxhatch
1990lxhatch's Avatar
Trust me, the removal of tapered bearings and inteference fit components isn't easily or properly done with pry bars and slide hammers. I still don't understand why people spend so much time and money to "fix" things and then shortcut obviously important steps. Dial indicators, special tools, slect-fit shims and torque specifications exist for a reason. USE THEM WHEN DIRECTED!!!
1990lxhatch is offline
Quick Reply: T5 rebuild
