How to change expoloer 65mm throttle body linkage to mustang
Old 04-13-2010, 08:20 PM
5.0stang.ryan
5.0stang.ryan's Avatar
Default How to change expoloer 65mm throttle body linkage to mustang
I got a 65mm exploder throttle body with the gt40 intakes. I want to change out the throttle linkage on the throttle body so it will work with my stock mustang linkage. I have read that this is possible but i wanted to find out how.
Thanks
5.0stang.ryan is offline
Old 04-13-2010, 09:11 PM
AdderMk2
Banned
AdderMk2's Avatar
possible yes, but will you waste more time and effort trying to get it to work, then if you just bought the right TB in the first place... also a yes
dont bother
AdderMk2 is offline
Old 04-14-2010, 08:03 AM
largedrag
largedrag's Avatar
Google is your friend
http://www.veryuseful.com/mustang/te...orer65mmTB.pdf
There are lots of writeups about this online.
largedrag is offline
Old 04-14-2010, 06:47 PM
351GT
351GT's Avatar
I was wondering this as well the article above was good. Are there anymore that have more step by step process along with more pictures?
351GT is offline
Old 04-14-2010, 10:42 PM
raven_ghostwolf
raven_ghostwolf's Avatar
dont bother
Adder still as positive as I remember. Guess you have never tried this or you wouldn't have said something so ridiculous?
I read the write up not sure why he would want both ***** on the linkage but ok. Apparently not all Explorer TB's are the same the one I am using had the oil breather tube and I had no issues with the tab for the TP sensor being too long as you can see in the following picture.
All I did was carefully grind down the edges of the post till the linkage would slide off on both TB's. I then put the Mustang linkage on the Explorer TB then with a punch and light hammer tapped the post end to fold over the linkage similar to the way it was. All this took very little time You could epoxy it I suppose or maybe drill a very small hole to run a screw into, I did neither and have never had it come apart for the year I drove the car like that before I got broadsided.
Sorry don't have any pictures of the finished TB linkage on the car but I did just take one of the old TB I put the Explorer linkage on that is still in my collection of parts. I didn't bother finishing this one up but even so it is very solid. Hope this helps.
raven_ghostwolf is offline
Old 04-15-2010, 01:26 AM
351GT
351GT's Avatar
Yeah the Explorer TB i got had the oil breather as well. Yeah that helped thanks
351GT is offline
Old 04-15-2010, 08:31 PM
5.0stang.ryan
Hey thanks for the help raven_ghostwolf. I am not sure why people say this is a hard thing to do. It took less than an hour to swap linkages and install. Thanks for the two pics really helped out alot.
djbigskrilla
09-20-2022 01:04 AM
01blackgtconv
08-14-2015 04:50 PM
stanngg
08-12-2015 03:43 PM
01blackgtconv
08-10-2015 01:25 PM
Quick Reply: How to change expoloer 65mm throttle body linkage to mustang
