17x9 problems
Old 04-27-2010, 10:11 AM
tohoopty
tohoopty's Avatar
Default 17x9 problems
ive got some 17x9 03 cobras and they hit the struts,and wont even bolt up.are you guys running spacers up front and if you are how much of a spacer.im also running 4 cyl brakes
tohoopty is offline
Old 04-27-2010, 10:20 AM
Tony71502
Tony71502's Avatar
Are you running a 5 lug conversion on a fox spindle? Or are these 4 lug rims? I'm using 17x9s with cobra brakes no problem. Then again my backspacing is slightly more than yours, I'm sure.
Tony71502 is offline
Old 04-27-2010, 10:24 AM
tohoopty
tohoopty's Avatar
these are the 4 lug rims and im running 4 cyl brakes right now.
tohoopty is offline
Old 04-27-2010, 10:44 AM
capri debris
capri debris's Avatar
I had the same wheels and had the same problem with my '86 Capri. I bought some 1/4" spacers to put on, but then I discovered I'd need longer lug studs if I used them. So, I went through the hassle of pulling the front rotors and rear axles to press in longer studs. That's what you're gonna need to do if you want to use those 9" Cobra Rs.
Or..... you could just sell me the wheels since I'm already set up to use them and have been looking a few months now for a decent set of 17x9 Cobra Rs.
capri debris is offline
Old 04-27-2010, 10:56 AM
tohoopty
tohoopty's Avatar
well i have a 8.8 in the rear.do i need to run spacers on the back too.ive already spent 600 on the wheels and dont wanna have to drop alot of money just to get them to work.well i just tried the back ones on and i have about an inch of clearance between the back of the wheel and the body of of the car
tohoopty is offline
Old 04-27-2010, 11:53 PM
tohoopty
tohoopty's Avatar
bump.some more info is greatly appreciated
tohoopty is offline
Old 04-28-2010, 07:35 AM
Tony71502
Tony71502's Avatar
If the back ones fit then your fine. For the front, you're going to have to do what he did to get spacers on there... or bite the bullet and get different rims. If you're hitting the strut, I'm interested to see how limited your turning will be before your rim hits the lower control arm.
With my sn-95 spindles and brakes, and more backspacing than you, I can only turn the steering wheel 1 1/8 rotations each direction before hitting the control arms... which is more than most people until you go tubular.
Old 04-28-2010, 08:49 AM
tohoopty
tohoopty's Avatar
well i hope i can get away with 1/4 inch spacers.ive always wanted these wheels and they are going to go on one way or another
tohoopty is offline
Old 04-28-2010, 11:12 AM
capri debris
They WILL go on and they WILL work, but only with the 1/4" spacers.
You MUST use them on the front as well as the rears too... even if the rears fit, it's going to look funny with spacers only on the front becasue the outer lip of the rim is going to stick out further in the front than the rear.
My '86 stock actually has a narrower track in the rear than in the front to begin with, so only using spacers on the front is going to make this situation even worse.
I used a 1/4" spacer on the front and a 1/2 spacer on the rear... this made everything look right and I had no rubbing on anything on the front tires either.
Here's a pic of my '86 Capri with that set up and Eibach lowering springs to boot:
Old 04-28-2010, 11:23 AM
tohoopty
tohoopty's Avatar
well i just picked up some 1/4 inch spacers.they look like they will work now.im gonna try them tomorrow once i get tires put on.how close are your rims and tires to the strut once you used the spacers capri debris.and also what size tire are you running in the front
tohoopty is offline
Quick Reply: 17x9 problems
