firing order
Old 05-24-2010, 10:28 AM
morgan62
morgan62's Avatar
Default firing order
what is the firing order on a 1995 302 ho with a e303 racing cam
morgan62 is offline
Old 05-24-2010, 11:10 AM
AdderMk2
Banned
AdderMk2's Avatar
the same as every other 302ho...
1-3-7-2-6-5-4-8
coulda googled that one
AdderMk2 is offline
Old 05-24-2010, 01:08 PM
morgan62
morgan62's Avatar
Default 1988 block
i used a block out of a 1988 bronco and used my heads and retro kit and roller cam and roller lifters does it make a difference on the firing order
morgan62 is offline
Old 05-24-2010, 03:07 PM
AdderMk2
Banned
AdderMk2's Avatar
consider, if you will... my post count, and the length of time I have been on this forum.
If your block, heads, and lifters could possibly make a difference in the firing order... dont you think i would have asked if they were not stock?
cylinder firing order is dependent on the cam, and cam alone. your injector firing order however is dependent on your ECM (which is probably stock) and should not affect your particular application
AdderMk2 is offline
bradleyb
11-27-2015 07:50 PM
bradleyb
California Regional Chapter
10-01-2015 01:02 AM
Drastang
09-30-2015 03:48 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: firing order
