Rear Sway Bar and Aftermarket LCA Question
Old 07-29-2010, 04:57 PM
87Stallion
87Stallion's Avatar
Default Rear Sway Bar and Aftermarket LCA Question
Am I right in saying that the sway bar mounts inside the control arms? I have aftermarket tubulars with just the bracket welded on underneath the control arm.
87Stallion is offline
Old 07-29-2010, 06:52 PM
badlx87
badlx87's Avatar
I think it depends on the brand as to how/where they mount.
badlx87 is offline
Old 07-29-2010, 07:09 PM
jimkaray
jimkaray's Avatar
As you know the bar literally mounts inside the stock lower control arm. If you're using the stock clip nuts in the stock orientation then the bolts would screw in toward the center of the car. That would mean the bar should go to the inbound side of the tabs. Thinking that through some more this would also give you maximum clearance with the tire sidewall. In reality it shouldn't matter as long as it is securely mounted and there are no clearance or stress issue with the mounting.
jimkaray is offline
Old 07-29-2010, 10:05 PM
87Stallion
87Stallion's Avatar
Thats what I thought but I wanted to make sure.
GimpyHSHS
08-29-2015 06:30 PM
cedarmn
08-28-2015 09:51 PM
Mobiusone stang
08-24-2015 04:08 PM
cedarmn
08-20-2015 03:14 PM
Quick Reply: Rear Sway Bar and Aftermarket LCA Question
