rocker arm advice
Old 08-13-2005, 02:26 AM
3stangs
3stangs's Avatar
Default rocker arm advice
I need lots of advice.I have a 94 GT and I'm having a set of Trick flow Twisted wedge heads installed. I figured I would go ahead and have a new set of rockers installed. Trick flow makes a set with a 1.6 ratio. Will i need to modify anything for the rockers ? Will the oil rods need to be longer or shorter or will the old ones work? Will the valve covers need modifing . Will this combo kill horse power to my pony? It has a stock cam and I don't want to change it rightnow. And last but not least should I get the heads with machined grooves for fel-pro loc-wire gaskets.
3stangs is offline
Old 08-13-2005, 03:32 AM
crazyhorse
crazyhorse's Avatar
Default RE: rocker arm advice
have you already bought this?
crazyhorse is offline
Old 08-13-2005, 03:47 AM
3stangs
3stangs's Avatar
nope
3stangs is offline
Old 08-13-2005, 04:05 AM
crazyhorse
crazyhorse's Avatar
summit racing sales a trick flow kit that comes with the trick flow tw heads, up/lower intake, cam, push rods, adjustable aluminum roller rocker arms, arp bolts, gaskets, trick flow valve covers, roller timing set . all correct parts to fit for $2049. this will give you 300-350 hp. i have this on one of my mustangs and i like it .
Old 08-13-2005, 04:11 AM
3stangs
3stangs's Avatar
Thanks ! I like the advice and the price but I'm buying it peace by peace cause I won't have all the money at once and it might get spent on junk if I don't. Pluse I don't have that much cash.
3stangs is offline
Old 08-13-2005, 04:13 AM
3stangs
3stangs's Avatar
Damn I wish I could get that kit!
3stangs is offline
Old 08-13-2005, 04:15 AM
crazyhorse
crazyhorse's Avatar
o k . the push rods are trick flow hardened 1 peice, summit or trick flow will know the correct length. good luck.
Old 08-13-2005, 04:18 AM
3stangs
3stangs's Avatar
thanks
3stangs is offline
Sixer4Life
10-12-2015 04:26 AM
UrS4
10-03-2015 06:23 AM
UrS4
09-30-2015 10:13 AM
uedlose
09-30-2015 08:01 AM
Sixer4Life
09-28-2015 07:05 AM
Quick Reply: rocker arm advice
