injector size????????????????
Old 08-14-2005, 07:39 PM
vfast
I ♥ Acer
vfast's Avatar
Default RE: injector size????????????????
95 cobra..that seems odd as I run 15psi using 42's
87...why is that intake not good?...it flow enough for a car with a stock cam with 8 psi..like I said before I run 15 psi and use a gt-40 intake..with gt-40 heads grants they flow very well...that black box intake doesn't do much when it's for a stock bottom...I have had great gains using a cheap ole truck lower and a edelbrock upper
vfast is offline
Old 08-14-2005, 07:46 PM
wildstang87
wildstang87's Avatar
first off, i asked that question about the truck lower a few days ago, could you explain the swap. which upper did you use. and i dont mean the intake wont support boost, but any box style manifold will produce better numbers on a forced induction setup, larger runner diameter with shorter runners allows the airflow to flow better at higher RPMs as a they dont need the smaller, longer runners to make torque. a stock manifold will support any amount of boost as well, i was simply saying which works best for the appl.
wildstang87 is offline
Old 08-14-2005, 10:48 PM
sup95cobra
sup95cobra's Avatar
ORIGINAL: vfast
How is it odd the new set-up is over 500 Rwhp......The boost amount doesn't matter it is the power you are making...Just another idea my blower produced 13psi with the old combo and the same blower only produces 6psi with the new combo
sup95cobra is offline
Old 08-15-2005, 12:15 AM
bbfao
bbfao's Avatar
ok, next question, where do i find the pulleys to run like 15 psi? You have to remember, I am not new to working on cars, just new to fords. I can do any of it with the right book or right answers. I plan on doing the work to the stang all myself. And how much would it benifit me to go with the glass doors and decklid???????? I appreciate all the help so far.
bbfao is offline
Old 08-15-2005, 12:16 AM
Quik
Quik's Avatar
boost is overated, juice is the hotness
Quik is offline
Old 08-15-2005, 12:18 AM
bbfao
bbfao's Avatar
in the long run the "juice" costs alot more, you have to refill the bottle, what do you have to refill on a supercharger?
bbfao is offline
Old 08-15-2005, 12:46 AM
Quik
Quik's Avatar
ha please, juice is nice cause you dont always use it. not saying i dont like boost cause i do but you get alot more out of juice then a blower. expect blowers sound so pimp.
and before you go on a rant about this and that. most boost numbers ive seen are 50% and that is with a intercooler/aftercooler
50% of a 302 ho is 112 hp
125 shot cures that very easy and thats for about 700 bucks or cheaper....whats the blower 1900 to 4k depending on the kit
so at 35 bucks a bottle and 700 for the complete kit. **** it will be a long time before i spend the same amount of money you blower guys just did. also blowers should get rebuilt every so often if used hard. so there is more money spent and i can get new solenoids for under 100 bucks. also new jets are about 15 bucks for a set and a pulley is what? 40.....
both are fun and im ****ing with ya but facts are facts
Quik is offline
Old 08-15-2005, 01:18 AM
bbfao
bbfao's Avatar
LMFAO i know and am even thinking of juicing on top!!!!!!!
bbfao is offline
Old 08-15-2005, 01:32 AM
94Cbra
94Cbra's Avatar
Thanks Quick, I agree that Juice is the way to go. And its about damn time someone else realized that once you buy a blower, its not there at 100% forever. Sooner or later your going to have to do maintenence, and somtimes its not cheap. All there is to an N20 kit is a few lines and some solenoids. Even Vortech recommends complete S/C overhauls at least every 20K miles. Twin Screws need to be rebuilt more often than centrifugals if you want to maintain optimal rotor tolerances. Where there are some that have S/C's that last 50K miles with no problems or performance loss, the projected life expectancy from the manufacturer's arent that impressive considering the initial investment.
Anyways, if your gonna S/C it, IMO you should go ahead and run the 42#'ers. That way you have some room to grow. Also if you get it tuned and setup properly, your driveability wont be any different than if you got the smaller injectors aside from the occasional throttle surge.
94Cbra is offline
Old 08-15-2005, 01:33 AM
Quik
Quik's Avatar
ive seen you drive, you got a lead foot, rookies dont use NAWZZZZ youll blow your motor up
Quik is offline
mltdwn12
09-23-2015 08:54 AM
Demodulates
09-18-2015 11:14 AM
pimp2303
09-17-2015 08:45 PM
uedlose
09-10-2015 01:37 PM
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
Quick Reply: injector size????????????????
