why does my car run dangerously hot
Old 09-10-2010, 08:10 AM
nitrous_fed_03gt
nitrous_fed_03gt's Avatar
Default why does my car run dangerously hot
so i blew a head gasket a month ago. bought new mls gaskets, and sent the heads off to the machine shop. they came back fine. so when im doing city driving, or just let the car sit at idle, the temp gauge creeps up dangerously hot, but yet highway driving it fine. i put some of that red line water wetter in. it didnt help. i wrapped some of my hot piping. didnt help. so i took the hood off, and that helped a lot. wtf is the deal????
nitrous_fed_03gt is offline
Old 09-10-2010, 08:13 AM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
electric fan or stock fan clutch set up?? if it's stock set up the fan clutch is most likely bad = replace
mjr46 is offline
Old 09-10-2010, 11:26 AM
AdderMk2
Banned
AdderMk2's Avatar
fan problem
AdderMk2 is offline
Old 09-10-2010, 01:04 PM
pete88gt
pete88gt's Avatar
t-stat not opening maybe? or fan?
pete88gt is offline
Old 09-10-2010, 07:40 PM
nitrous_fed_03gt
has a new thermostat. Still on stock belt driven fan. Could it be the radiator? Maybe it can't keep up with the heat from the turbo set up?
Old 09-10-2010, 07:43 PM
fordboy5.0
fordboy5.0's Avatar
are u running the egr spacer?
fordboy5.0 is offline
Old 09-10-2010, 08:26 PM
AdderMk2
Banned
AdderMk2's Avatar
its...
a...
fan...
problem.
If its still the stock fan, See if the fan will spin when the car is cold. It should spin freely with some, but little resistance.
Warm the car up... shut off the car, lol.. then try to spin the fan by hand. It should be SIGNIFICANTLY more difficult to spin. If it is not... replace the clutch.
AdderMk2 is offline
Old 09-10-2010, 09:19 PM
fordboy5.0
fordboy5.0's Avatar
oh man...
how i love...
this....
forum....
Old 09-10-2010, 10:21 PM
nitrous_fed_03gt
I will try what u said adder and let u kno. Thanks guys
Old 09-10-2010, 10:23 PM
JD1969
Pro. B.S. caller outer
JD1969's Avatar
People, this is why Adder is saying it is a fan issue. At slow speeds the fan is not pulling enough air over the radiator to cool the engine. At highway speeds there is enough airflow that the fan does not matter. Makes a ton of sense to me, and it would be the very first thing I would check.
JD1969 is offline
Quick Reply: why does my car run dangerously hot
