88 LX with AOD?
Old 10-08-2010, 08:43 AM
kolb02
kolb02's Avatar
Default 88 LX with AOD?
I just bought a 1988 LX 5.0 with AOD in it. My question is what should I do to make this tranny a better street/strip performer? Is there a shift kit to get?
kolb02 is offline
Old 10-08-2010, 11:52 AM
1ATony
Former Sponsor
1ATony's Avatar
I have a TCI street fighter and it's to much for the road. My advice would be to go to a well know tranny shop in your area and tell them what you're looking to do.
If you just go to the track once in a while I'd just do a mild shift kit and call it a day.
1ATony is offline
Old 10-08-2010, 01:03 PM
ford1991mustang
ford1991mustang's Avatar
yeah a shift kit would help out. I would suggest also getting a transmission cooler. I had a B&M hammer shifter for my AOD and it makes driving alot more fun.
A new valve body or higher stall converter will make your trans more aggressive but is more costly.
ford1991mustang is offline
Old 10-08-2010, 07:19 PM
enix187
enix187's Avatar
trans go, you can pick how stiff you want it to shift, allows you to shift into overdrive at full throttle, and you can hold out the gears longer with it in low. Also it allows for a more instantaneous forced down**** (moving from d to l). I would recommend that if you're not familiar with tranny work you get a shop to do the labor, its difficult to install the new valve body springs and if you want the full kit you have to drill the valve body too. Its a great upgrade with a rebuild. 1 shim=kind've harder shifts 2 shims= noticeably firmer shift (this is what i ran, with the line pressure turned up it would bark the tires on the second shift) and three shims, well I've never run three so i don't know. We've had this kit installed in three different transmissions two aod's and one th350, its a great kit.
enix187 is offline
Old 10-09-2010, 12:03 AM
micus
micus's Avatar
i think the b & m stage 1 kit can be had for around 45 dollars, all you have to do is drop the pan for the install. i ran out of love for my AOD = t5.
micus is offline
Old 10-09-2010, 01:54 PM
FLcracker9
FLcracker9's Avatar
Transgo or Baumann Electronics for the shift kit, stay away from the B&M for the AOD. Also another cheap upgrade is an A or A+ servo. Both the kit and the servo can be installed by most in a couple of hours at home.
FLcracker9 is offline
Old 10-09-2010, 06:59 PM
Gator
Gator's Avatar
heres what i did, spt-1 stage 2 from here http://www.silverfoxtrans.com/silver...om/VB_AOD.html
call and talk to Dan he will suggest the best for what youre trying to do, and can set it up how and where you want it for shift points firmness etc.
Great product support here also
I installed my valvebody myself, i have never been inside a transmission, and know nothing about them. comes with easy to follow instructions, no drilling needed its already done, comes ready to bolt in and go
check here for AOD tech forums http://www.clickclickracing.com/forums/forum.php
Gator is offline
Old 10-10-2010, 10:08 AM
nitrous_bob
nitrous_bob's Avatar
imo you have only 2 options
1) lentech aod http://www.lentechautomatics.com/
2) t5 swap
i spent way too much money in the past to have an inferior trans too many times to even consider an aod for anything
but if i fell off the high dive, broke my head and thought about it for a minute... i'd go lentech
and it's not just the shifting thats an issue... and a shift kit wont fix all of the issues
the biggest issue is gearing. an aod is 2.40 1st compared to a 3.35 in a t5, the shift points will be raised a little a shift kit, but the 2-3 shift will still come in way too low and since the aod had 3-4 in the same spot... you cant lock out 2 without doing the "shuffle" and that will smoke the trans due to some clutches being engaged when they shouldnt be because the trans thinks it's in 3rd when it's really in 2nd.
the converter flashes way low... even a 2200 will feel stock so if you do a aod... go 3k or bigger... or dont bother cuz you will feel dissapointed.
they are also susceptible to heat more than your typical automatic so make sure you get a cooler on it too
considering all that.... price a lentech, compare that to an $1800 rebuild for a STOCK AOD REBUILD and you'll see where im coming from
len can electronically delete the 4th gear so you can manually shift 1-2-3 in the 1-d-od positions... then hit ta button for od to come on in normal driving
whan i talk about the "shuffle" i mean going from 1-d-1 to lock out 2nd.... dont do it unless your planning on throwing that trans away anyways in the next 6 months
nitrous_bob is offline
Old 10-10-2010, 01:57 PM
sixtyninestang
sixtyninestang's Avatar
I fully agree. The shift kit in my car makes it klunk going into overdrive if you don't have your foot into it. I can't stand it, but it's great for the strip, where you're wide open.
sixtyninestang is offline
Old 10-10-2010, 02:12 PM
foxbod90
foxbod90's Avatar
my aod goes klunk into overdrive as well. i dont think it has a shift kit but, maybe it does!
foxbod90 is offline
Ryan Fitzpatrick
09-14-2015 02:21 AM
CarrieS
09-01-2015 01:00 PM
TAC_Sisco
01-08-2004 06:33 AM
89 GT
11-18-2003 03:24 PM
MustangGT95
07-31-2003 02:56 AM
Quick Reply: 88 LX with AOD?
