Finishing 4 cyl to v8 swap no power help pls!!
Hi whats up guys>? I just finished or am finishing up a 4cyl to v 8 swap, i had a 91 4 cyl chassis and i had a complete ruinning 90 chassis i swapped everything from the 90 into the 91 Dash All the wiring harnesses, EVERYTHING when i mean everything both chassis where totally stripped basically i gotta 91 fox with the heart of 90 fox, I threw my battery in today to blead the power steering and ****, and I HAVE NO POWER to anything no door chimes interior lights, nothing, when i jump the solenoid the starter cranks and that is it, If anyone can Help me out asap with some ideas Id be more than gratefull, i need to get this car back on the road its my daily driver and i havent had it in about 6 or 7 months
checked grounds
i checked all my grounds, sanded cleaned, re attached, theres the ground on the neg batt cable, behind the drivers side cylinder head, one by the computer, all the little headlight ones but that woudlnt apply here my headlights just wouldnt work right? ground to the block from the battery, but what i dont understand is why does my starter crank?
Matt's 95 Stang
10-05-2015 07:16 AM
uberstang1
09-20-2015 06:42 PM
