Black oil?
Old 11-03-2010, 10:31 PM
rprice180
rprice180's Avatar
Smile Black oil?
I've been noticing a couple of things with my motor. First when you hit about 4500rpms it blows a little blue smoke and is kinda embarrassing and was wondering if it was time for rings, valve seals, or something else that i dont know about (any ideas to help). Plus the pcv line going into the upper intake is wet with oil so i was wondering if it was possible this could be the problem. 2nd i got an oil change not to long ago and i checked the dipstick and noticed the oil is very black but doesn't smell burnt. The car is running rich but whats going on? HELP...........
rprice180 is offline
Old 11-03-2010, 11:29 PM
enix187
enix187's Avatar
sound like a good excuse to replace a motor!
but really, the blue smoke is a common worn out 5.0 trait, it also sounds like your pcv is bad if its soaked with oil, the blow by from worn out rings will over pressurize the oil and blow it where it shouldn't go. If you get a wild hair across your tail go out, fire her up and take the oil cap off, it shouldn't change the way it runs much (if any)
enix187 is offline
Old 11-04-2010, 11:12 AM
rprice180
rprice180's Avatar
Cool
Really, i've been looking at local engine shops about a rebuild plus i've been looking at summit at the x302 remand motor any. dont know where to go i guess i have to don some research then. why should i take the oil cap off while its running ? do you know of a good engine shop that will do it right
Old 11-04-2010, 11:44 AM
enix187
enix187's Avatar
if you take the oil cap off and the idle changes then you're getting blow by in the cylinders some how. If you really want to know do a compression test. As far as crate engines go mmff(could've been mm) just had a great write up on the frpp crate
http://www.latemodelrestoration.com/...P-Crate-Engine
enix187 is offline
Old 11-04-2010, 01:55 PM
67mustang302
67mustang302's Avatar
Sounds like rings most likely. Blowing blue smoke = burning oil, and if the oil is getting filthy right away it's most likely excessive blow by contaminating the crankcase.
67mustang302 is offline
Old 11-04-2010, 09:52 PM
rprice180
rprice180's Avatar
Cool
I pulled the oil cap off while it was running and warmed up and nothing happened?
Old 11-04-2010, 10:00 PM
enix187
enix187's Avatar
well thats a good sign, now if you want definite answers time for a compression test! go rent/buy a compression tester and run the test!
enix187 is offline
Old 11-04-2010, 11:43 PM
rprice180
rprice180's Avatar
Cool
allright man its gonna take me a couple of days to get some time together to check but i'll hit you up later. thanks for the help.
Old 11-05-2010, 03:56 PM
SLCustomsGTCS
SLCustomsGTCS's Avatar
Not saying its the right thing to do but being that I used to be a used car salesmen I know a few tricks to getting rid of the blue smoke.
first thing we used to try is marvels mystery oil and Lucas with an oil change.
next was a full synthetic oil. I would only recommend this as a cover up of the smoke not a long term solution.
So I don't seem to much like a jerk, We also included a warranty with every car we sold that would have covered the motor blowing up.
SLCustomsGTCS is offline
Old 11-09-2010, 08:08 PM
rprice180
rprice180's Avatar
Cool
So i pulled a plug out to start a compression test and when the i looked at it and noticed it was covered in burnt oil. So is this a good sign that the rings are gone?
Quick Reply: Black oil?
