90 5.0 GT airbag help
Old 12-16-2010, 04:47 PM
Bowtietraitor
Bowtietraitor's Avatar
Default 90 5.0 GT airbag help
Hey all- Just registered here and over at mustangworks. I'm trying to debug my new toy, and since it's my first ford I don't know the electrical like I do on Camaro's & Vettes- so I'm hoping someone will be able to point me in the right direction. I'm gonna cut'n'paste my thread from mw so I don't have to type it all twice- hope nobody is offended...
Another noob here needing advice on my first ford. I just picked up a 1 owner 112k tripple black 90GT vert in really nice shape, or so I thought, until I started debugging the dash & found my share of troubles...
After replacing the flashers(not where the book says...) and all the bulbs in the dash while installing a new speedo cable I found that not only does my cruise not work, but I also have the airbag light on constantly. I've tried to get the srs module to flash out- to no avail the light just stays on. I've done enough research to know the clocksprings in these are suspect, and since there are no new ones to be had(I called 2 dozen dealers nationwide & also talked to the R&D people at Dorman about making them...) I went ahead & ordered a used one from Robbie at MPS along with the module and external power supply. I figured since I'm throwing parts at it I'd hit the big 3 to start with, at least this way if it doesn't fix it it'll at least give me a code- right?
So anyway- no cruise, airbag light always on w/ no codes... am I on the right track? Any info would be appreciated. Also- does anyone have good diagnostic charts for these systems? Alldata doesn't have anything past generic, and my solus scanner doesn't troubleshoot dino-tech...
Thanks!
Bowtietraitor is offline
Old 12-16-2010, 08:56 PM
Bowtietraitor
Afterthought- is there a diagnostic port for the srs system I don't know about? & do I need dealer diagnostics? I have a v9.2 solus, & all I see in my menu is engine & trans menus.
Urambo Tauro
10-05-2015 09:37 PM
Matt's 95 Stang
10-05-2015 07:16 AM
ChampInSD
10-02-2015 04:55 AM
mungodrums
09-28-2015 10:54 PM
treesloth
09-28-2015 07:03 AM
Quick Reply: 90 5.0 GT airbag help
