starting a project a need help?
hey guys, i have not been on this site for awhile and i just getting back and i need some help. I have a 1990 lx and i'm doing some research on where to begin for doing the motor over. I have been told by a couple of mechanic friends of mine that my motor has been beat on bad ( its has a bad shimmy in it and also is blowing blue smoke driving down the road) and is time to be replaced. my question is is it better to bring my current motor to a machine shop knowing that it has problems or it it worth starting fresh. Whatever i do i want to do a 347 stroker motor. I have been looking at dss racing and dart so far, so what do you guys think?
I wouldn't worry about the screw-in freeze plugs. The deep seat type type works fine when just a little lock-tite is used on them.
Don't forget to remember cylinder heads when planning your project.
347's don't run right with 302 parts on them.
If you are thinking of using a solid roller cam like I did, you need different cam bearings than you would other wise use......
Boostaddict
Lethal Performance
09-08-2015 09:56 PM
