car will not start
Old 04-21-2011, 09:16 PM
adshr
adshr's Avatar
Default car will not start
ok so here is the deal when i turn the key the car just makes a clicking noise i have replace the starter and battery and it still does the same thing click click click i have check the connections over and over again and dont know what to do now any ideas
adshr is offline
Old 04-21-2011, 10:54 PM
nitrous_bob
nitrous_bob's Avatar
how many volts do you have at the battery ?
did you try to jump the selonoid yet ?
nitrous_bob is offline
Old 04-23-2011, 10:31 AM
buster
buster's Avatar
did you replace a dead battery with a dead battery?
buster is offline
Old 04-23-2011, 10:37 AM
buster
buster's Avatar
did you repalce a dead batery with a dead battery?
buster is offline
Old 04-23-2011, 11:18 AM
stdyhand
stdyhand's Avatar
Bad ground maybe?
You could also make sure the engine didn't seize up. That would be worst case and unlikely.
If you replaced the starter I would make sure you got the power wire and any ground wires tight and they are clean.
Def have the battery checked. Just because it's new doesn't mean it isn't bad. It happens.
Also do what NB said and check the selonoid. Use a screwdriver and with the key in the ON position jump one terminal to the other and see if the starter turns over. If it does, replace the selonoid.
stdyhand is offline
Old 04-23-2011, 01:45 PM
adshr
adshr's Avatar
i dont think its the battery cause i even took the battery out of my car i drive daily and it did the same thing
adshr is offline
Old 04-23-2011, 08:38 PM
My89Gt
My89Gt's Avatar
I will say that ford has always had a big problem with solenoids. Definitely would be one of the first things I would check.
My89Gt is offline
Old 04-24-2011, 12:51 PM
adshr
adshr's Avatar
it was a bad ground
adshr is offline
djbigskrilla
09-20-2022 01:04 AM
mstahoo
SVT Forums
08-19-2021 09:15 PM
msavoia23
12
07-07-2018 12:08 PM
92 5.0stang
08-13-2015 06:46 AM
Milan Dragway
08-12-2015 03:43 PM
Quick Reply: car will not start
