fuel problem....
hey guys im a little new to the mustang word but i need some help!! i just bout a 92 GT from a guy that had already done some mods to it. Its got new intake, gt40 heads, cam, headers, exhaust, x pipe, and he put an aftermarket fuel pump in it.
He wasnt sure on the brand but im having a problem with it flooding itself out. when u go to start if u do not push the gas when it tris to turn over the first time it will flood itself. I have to undo the fuel injector harness and start it to run the fuel out, then plug it back in and try again. It will flood unless u get it the first time it turns over.
anyone have any ideas on what i need to do to correct this problem? thanks in advance
On ur self test connector on the driver side under the hood I believe it is a gray/red wire I will have to double when I get home but u need to ground that wire and problem solved. I went through the same issue for months and hours of tracing wires to figure out that it was a bad ground. Lmk how it works for you..... I will post the wire color when I get home.
mrappe
Sep 26, 2015 10:16 AM
