SN95 Alternator Bracket
I have a set of stamped steel edelbrocks that clear, but i cant vent the crankcase pressure with them. These valve covers are not getting touched.
Im working with the owner of a company to get a bracket developed, so we can stop having so much trouble with these front accessories.
All it really needs is to be rotated away from the center of the car slightly. So even a spacer and small metal strap from the top bolt would help tons!
I'll probably do this when I come home from this deployment
try this
Try this it works for me. Take a 1" block of aluminum 2.25" long and 1.5" wide. In a press drill hole to accommodate a 5/16" bolt. Bolt needs to be 3.75" long need a nut for bolt. Use piece of aluminum 1/4" thick 1.25" wide and 2.75" long. Weld block with hole to alternator bracket make sure alternator is aligned with hole . Bracket was off car when I did this. Then put a slight curve on thinner piece to form a brace on top, weld this piece.
