push rods and rockers
Old 09-02-2005, 05:28 AM
3stangs
3stangs's Avatar
Default push rods and rockers
I plan on changing my rockers to 1.6 and am wondering if I will need to change pushrods. My heads are stock heads and if I change rockers will I need different valvecovers.Also what will a 1.6 ratio do for my stock motor.
3stangs is offline
Old 09-02-2005, 05:29 AM
3stangs
3stangs's Avatar
Default RE: push rods and rockers
almost forgot . MY motor is a stock 94 5.0 .
3stangs is offline
Old 09-02-2005, 08:27 AM
Quik
Quik's Avatar
you do know that you have 1.6 rockers now. so changing them to RR 1.6s wont matter for PR lenght
Quik is offline
Old 09-03-2005, 07:08 PM
3stangs
3stangs's Avatar
no I did not know that a 94 5.0 had 1.6 rockers . so how would stock heads handle 1.7 rockers .
3stangs is offline
Old 09-03-2005, 10:41 PM
92hatchLX
92hatchLX's Avatar
It's a popular bolt on that's worth some ponies, your heads can handle it and your piston/valve clearance will be alright, I'm not sure if you'll need diff. push rods though.
92hatchLX is offline
Old 09-05-2005, 06:56 AM
tchamber
tchamber's Avatar
No, you don't need new pushrods for his mod. You may need some thicker valve cover gaskets, or new covers. I have 1.7s in my 95GT, and only did it because I had my heads redone with bigger valves and a little porting done. If you're not taking the top end apart, don't bother, go get a new, shorter, rear end, or a CAI, or headers.
tchamber is offline
Old 09-05-2005, 07:03 AM
3stangs
3stangs's Avatar
i plan on getting some heads with larger valves and thought it a good idea to change rockers. I wasn't sure what I would need to go up a size. What heads did you go with and how did it turn out. And do you know a good set of valve covers that will clear the valves.
3stangs is offline
Old 09-05-2005, 07:06 AM
3stangs
3stangs's Avatar
i mean clear the rockers. sorry valves on the brain.
3stangs is offline
Old 09-05-2005, 07:08 AM
tchamber
tchamber's Avatar
I actually just ported my stock heads myself, and took them to a shop to have oversized valves thrown in. Did a cam at the same time, and valve covers, headers, and tbody. Runs like a champ, just want a dyno/custom chip tune now. Don't know what pushrods you will need with new heads, but if I had money, I'd buy some AFR 165s. Ask the guys where you will buy your heads from for some tech advice, or try summit, they have answered a lot of questions for me.
tchamber is offline
3stangs
3stangs's Avatar
alredy have 410 gears in rearend and hardened gears in tranny.
3stangs is offline
Quick Reply: push rods and rockers
