PTV issues
Old 07-26-2011, 06:17 AM
1987notchback
1987notchback's Avatar
Default PTV issues
so i have a stock cam stock pushrod length but new 1.7 rr's. i checked ptv and there is not enough clearance... the two spots at the top of the valves pushed the clay so thin it is transparent. i could not even get the clay off to measure it but it is def to close. the headgasket is a stock thickness used 2 modified lifters. would a thicker headgasket or shorter pushrods help? the heads have been milled and i think the previous owner also had them milled bc there is almost no material from the valve to the deck. one valve may even may be higher than the deck by a hair. help! thanks mike
1987notchback is offline
Old 07-26-2011, 07:39 AM
1988TTOP
1988TTOP's Avatar
what pistons do u have cause u should have room
1988TTOP is offline
Old 07-26-2011, 07:55 AM
AdderMk2
Banned
AdderMk2's Avatar
There should be plenty of room. My questions would be:
Are you still using stock pushrods?
Did you degree the cam?
What method did you use to check PTV?
AdderMk2 is offline
Old 07-27-2011, 06:17 AM
1987notchback
no i did not degree the cam, i used the clay method
Old 07-27-2011, 06:18 AM
1987notchback
the pushrods are stock length just hardened. thanks mike
Old 07-27-2011, 06:26 AM
1987notchback
they are stock pistons
Old 07-27-2011, 07:02 AM
AdderMk2
Banned
AdderMk2's Avatar
IIRC, i told you to retard the stock cam...
AdderMk2 is offline
Old 07-28-2011, 04:49 AM
1987notchback
i did would that have somthing to do with it? sry for the dumb question. mike
Old 07-28-2011, 05:35 AM
AdderMk2
Banned
AdderMk2's Avatar
What size valves are in those performer heads?
You shouldn't be having this issue.
AdderMk2 is offline
Old 07-28-2011, 09:03 AM
sn95_331_GT_ yellow
sn95_331_GT_ yellow's Avatar
im just gonna throw it out there...
HOW did you retard the cam?...
sn95_331_GT_ yellow is offline
Quick Reply: PTV issues
