AOD question.
Old 08-30-2011, 02:55 PM
Shaft
Shaft's Avatar
Default AOD question.
I have. 93 5.0 with AOD. I know hardly anything about automatic transmissions so I'm hope y'all can help.
From standstill through first it's fine. First to second is fine, but it shifts real quickly into third. From third it will rev the RPMs really high until shifting into Overdrive. Sometimes I have to let off the gas before it will shift. Fluid levels are good. Any ideas?
Please don't tell me to rip out the AOD and put in a manual because that will never happen.
Shaft is offline
Old 09-01-2011, 08:15 PM
tredogg_82
tredogg_82's Avatar
a stock aod tranny does not hold 2nd gear to hold second gear you go up into drive then back to 2nd before it can shift
tredogg_82 is offline
Old 09-02-2011, 05:35 AM
4rdnut
4rdnut's Avatar
Rip the aod out and get a c4 transmission sorry couldn't resist. I had the infamous aod in my car and all i can tell you is, once it starts acting up, like shifting weird, it can't be fixed, because with this trans you will solve one problem then another problem arises. I learned the hard way and spent way too much money on the aod and still ended up with a lemon trans. I put a c4 trans in and couldn't be happier, the c4 trans automatically and manually shifts instantly when you want it to, not like the slow retarded aod. Ford engineers were drunk when they designed the doa trans.
4rdnut is offline
Old 09-02-2011, 04:09 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
You are experiencing the normal issues that AOD has....OD burning out....The AOD can be rebuilt to be a decent trans but if you want one fully built it will cost you twice as much as a c4. If you want to keep an AOD just get it rebuilt with better bands and a few internal mods then do the epoxy mod on the valve body....
talk to the guys at www.clickclickracing.com
projectresto83 is offline
Old 09-02-2011, 04:17 PM
Shaft
Shaft's Avatar
Good information guys. It gives me some stuff to think about. I want to keep the car an automatic.
Shaft is offline
tmdm
05-02-2021 02:49 PM
Daddys Girls GTs
09-14-2015 08:46 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
CarrieS
09-01-2015 01:00 PM
mdj89
08-31-2015 07:27 AM
Quick Reply: AOD question.
