89 GT T-5 issues
89 GT T-5 issues
I just bought an 89 GT 5.0 with a T-5 5 speed, and recently it started to develop a whining noise when in gear, it stops when the clutch is pushed in. It also grinds going into 3rd unless I take considerable time shifting into it, and will sometimes pop out of 2nd. It has a Hurst Tri-Ax short throw, and I dont think it has an adjustable clutch cable. It shifts into the other gears no problem, and I personally filled the transmission with 5.5 quarts of ATF.
So I'm looking at a rebuild either way. I was told when I bought it that the trans was brand new, so I guess the s.o.b. lied through his teeth to me, which is to kinda be expected I guess. He also tried to tell me that the motor was a crate 306 which it very clearly isn't, and couldnt produce any receipts. Either way I traded a junk motorcycle for it and it runs fine otherwise and the paint and interior is flawless. So what kind of money am I looking to spend if I rebuild it myself and how difficult is it?
If you can pull it yourself, take it to a reputable local transmission shop for a bench rebuild. I had a Jeep transmission and transfer case both done for $750 which included kits for both. Then you know it is gone over by somebody who knows what he is looking for problem-wise.
I'd rather go into it myself, I'm a wheel vehicle mechanic in the army so I have a full complement of whatever tools I may possibly need, plus being in a military town there are a lot of predatory businesses around, I just don't trust any of the local shops. Any suggestions on which rebuild kit I should go with?
