anyone here rebuilt their engine?
had low compression on my engine and found out it was the rings. i tore it down to the block. the machine shop now has my rods pistons and crank and block. the machine shop called and said they didnt have to take anything off of the crank and only needed to hone the block. so how hard is it to put the bottom end back together? my friends who are certified mechanics used to rebuild engines back in the day. they say all i have to do is make sure i get the right sized bearing and rings and put it back together but i know there is more involved like measurements. they actually just changed two bearings on a focus that was knocking without measuring a thing and it doesnt knock anymore. i think it was just luck. i have a limited amount of money. machine shop charged me $150 to do everything so that was good. i dont expect this engine to last me 100k. just need it to last me until January. i also dont have a book. dont have the money. i have a complete engine rebuild kit. and ring tools for the pistons. what else do i need to know?
doesnt matter how long u need it to last just do it right. its simple with the pistons u need a ring compressor and a butt of a hammer to get them in just clock the rings right and push through making sure not to hit the crank journal and put assemly lube on the cap bearings and make sure the tabs are going the right way..and torque the rod caps. but first the crank gets torqued. i mean this is a quick way of explaining. u need to get a manual or a tech like myself to do it for you. but its not hard..
I use lucas instead of assembly lube. I don't put the rest of the lucus in the engine when done though. The most wear in an engine comes in the first few hundred miles. All that crap will stick to Lucus so, don't use it in the pan. I also polish my bearings which no-one else I know of does except the person that tought me. Make sure you don't scratch the crank or cylinder walls and don't forget to prime it before start-up.
You'll need to get (or barrow) a few things like a torque wrench, a ring installion tool and maybe a friend who knows what he's doing to hang over your shoulder and watch.
Plan on getting a new rear main seal also. Plan on filing the new rings to get the end gap right.
If you go to the local library they should have a book about rebuilding you small block Ford.
BTW, watch out for the 'up side' on the rings, it makes a differance.......
