newer issues.
Old 11-15-2011, 10:03 AM
ColamanGT
ColamanGT's Avatar
Default newer issues.
Got an 87 GT. Just threw my flexplate in a month ago and barely drove the car. The other day I noticed when put into OD, it shifted into third really early. I purchased the Lokar TV cable. Any proper way to set up brackets and adjust cable?
Also, i have a hurst shifter. Was wondering if shifting from 1-OD is terrible for my transmission.
If so, anything hard with installing a manual valvebody?
Im pretty decent hands on, so anything isn't an issue.
ColamanGT is offline
Old 11-15-2011, 09:44 PM
projectresto83
M.A.D. Motorsports
projectresto83's Avatar
What was wrong with your stock TV cable?
If you purchase a manual VB then no, its pretty easy....drain the fluid, drop the pan, unbolt the stock VB, bolt in the new one, install the pan, fill and have fun.
When did it actually shift into 3rd? (speed, RPM,.....)
projectresto83 is offline
Old 11-18-2011, 05:18 PM
ColamanGT
ColamanGT's Avatar
Guy before me had an OEM lokar. But he screwed up the brackets, so i had to throw in another.
itll usually ****** 3rd around.. 20. Almost instantly after second. Speedo doesn't work so hard to tell.
Might have a bad VB. How much does a MVB run? Few hundred?
lincolnshibuya
12-08-2015 04:37 PM
UrS4
09-30-2015 10:13 AM
mungodrums
09-29-2015 09:18 PM
mungodrums
09-28-2015 05:45 AM
rdog69t
SVT Forums
09-13-2015 06:16 PM
Quick Reply: newer issues.
