Unknown part in automatic overdrive transmission
Old 11-26-2011, 05:11 PM
e_nelson36
e_nelson36's Avatar
Default Unknown part in automatic overdrive transmission
Does anyone know what this part is? It is off of a 1985 Mustang 5.0. It fell out of my automatic overdrive transmission as soon as I took the tranny pan off (so I didn't see it fall) and I can't seem to find anywhere that it is supposed to go and was unsure of the name or how to look it up. I have asked people at auto parts stores and also bought an automatic tranny overhaul manual and still havn't had any luck. Any ideas would be greatly appreciated.
Thanks,
Eric
e_nelson36 is offline
Old 11-26-2011, 06:52 PM
mustangGT86_05
mustangGT86_05's Avatar
Heh surprisingly another guy asked not too long ago, its an assembly line part used to plug the dipstick tube hole and falls in when the tube is installed. It just gets thrown away, but means your fluid hasn't been changed. How many miles does your car have?
mustangGT86_05 is offline
Old 11-26-2011, 07:21 PM
e_nelson36
e_nelson36's Avatar
oh alright thanks man. That's greatly appreciated. We were dumbfounded tranny shifted good when we got it tho. And not sure how many miles engine still runs excellent too tho.
Old 11-26-2011, 07:50 PM
mustangGT86_05
Not a problem, the only reason I ask is that if the tranny fluid gets so worn or burned, you aren't suppose to change it. I normally go with its good as long as it isn't burned but some people say don't touch it if its over 100k miles
Old 11-26-2011, 11:07 PM
e_nelson36
e_nelson36's Avatar
oh. Well we've already taken the filter off and dumped it so kinda late now. I've never heard of that tho. I've always been taught that if any area has internal wear and tear and fluid lubricating it then its best to change it.
Old 11-27-2011, 12:54 AM
mustangGT86_05
I can't remember the exact details but its something like the tranny grows use to working with the debris that's in it and since tranny fluid is very detergent, it will wash that stuff out and you can do the math. Its sort of like how you don't clean a high mileage engine if it never has been because it can cause leaks. You should be ok if the fluid wasn't real dark or smelled burned.
AMAlexLazarus
AmericanMuscle.com
21
04-04-2020 02:16 PM
mungodrums
10-07-2015 04:01 AM
Pyrate Dave
09-10-2015 07:30 PM
Steve@CJPP
CJ Pony Parts
09-03-2015 11:43 AM
Quick Reply: Unknown part in automatic overdrive transmission
