Power Window Problem
Old 12-30-2011, 03:17 PM
rockinstephen
rockinstephen's Avatar
Default Power Window Problem
Hello All! Today I was raising the power windows on my '92 LX convertible. They all went up OK but now the rear drivers side window is stuck in that position. The motor is working but the window won't budge. Anyone have any idea what the problem might be? Thanks in advance! Steve.
rockinstephen is offline
Old 12-30-2011, 04:27 PM
mattdel
mattdel's Avatar
Just because a motor makes noise, doesn't make it good. Going down is the easy part, a dead motor will allow a window to go down.
mattdel is offline
Old 12-30-2011, 04:41 PM
rockinstephen
Default Stuck Up
The window is stuck in the up position. I think something in the mechanism broke or wore out. I'm looking for an answer to what might be a common problem that someone has had expeirence with...
Old 12-30-2011, 04:46 PM
mattdel
mattdel's Avatar
Oh well you weren't clear on that part. Most of us long time members here are pretty knowledgeable on mustangs and cars as a whole, so don't go throwing your tongue around.
Stuck UP is usually a symptom of a broken regulator cable, but also could be the motor bushings.
mattdel is offline
Old 12-31-2011, 05:29 PM
rockinstephen
Thought I made it perfectly clear as to what the problem was...Anyway, I have some good leads on a couple of shops that specialize in this type of problem. I'll have it checked out later this week...
Old 12-31-2011, 09:54 PM
enix187
enix187's Avatar
mattdel hit the nail on the head, even if he hit it rather hard.....
you could do the fix but if you can find a shop to do it at a decent shop I would, these rear windows are impossible to get lined up properly
enix187 is offline
Old 01-03-2012, 11:59 AM
rockinstephen
Smile Problem Solved!
I took the car to a local shop today. 2 1/2 hours later they called to say it was ready. The problem was a stripped plastic gear. They installed a new window motor gear kit which included metal gears. They had the kit in stock as apparently this is a common problem on older Mustangs. It wasn't a cheap fix ($176.55) but at least the problem has been solved. Also, I have found a shop with friendly & knowledgeable folks. It's hard to put a price on that...
NorthAmericanTuning
11-09-2016 11:45 AM
NorthAmericanTuning
03-18-2016 11:21 AM
JonnyBlazeGT
11-03-2015 01:10 AM
movielover40
08-27-2015 10:13 PM
HorsePower99
08-26-2015 11:29 PM
Quick Reply: Power Window Problem
