94 Gt rear axles and brakes
Hey fellas I got a few questions for ya, first off this weekend me an a buddy were at the yard just looking for a door panel for his grand prix and as we're looking I come across a 94 gt pretty much complete just without a motor!! So like a child on Christmas I couldve pissed my pants with excitement ! So being pressed for time and not having the right amount of tools bc we weren't prepared we quickly pulled the axles an the rear disks prob should of taken the whole rear end but there was no room we were in a car sucks cuz we were from outta town and they closed at noon on saturdays
1. Will the axles(28 spline?) go into my fox rear diff?
2. If so, than the rear disks will work too right??
I pulled these parts outta pure enjoyment so if they won't go than oh well no biggie but I'm hoping they will work cause I've always wanted disks all the way around, I know I probably should of got the rear complete to make it easy.
Any info will be greatly appreciated thanks guys
Fwiw: before I posted I cross referenced rear axles between a 94 v6 and a gt and they both had the same part numbers and said they were 28 spline. Don't know how accurate this is but maybe someone can chime in
yes, the SN-95 brakes will fit the fox axle. Did you take the backing plates? Did you take the flanges? Did you take the anti-moan brackets? Did you take the brake lines?
You should have taken the entire axle.
Make sure you look up an sn95 or turbo coupe rear end swap guide before converting to disc, its not as easy as just tossing them on and going. The biggest pain is finding a way to plug the stock pv, I used a machine shop
That shouldn't be a prob bc I'm a welder in a metal fab shop so i have access to many awesome tools lol.
I tig weld aluminum mainly so if anyone wants anything melted lemme know not a prob :-)
This is all i got, i got the brackets that the calipers mount to, the brackets that also are connected with u bolts to the axle housing and all the brake lines..front and rear, my only question is will it all work even tho there are those abs cogs on the axles...can i take them off or will it be ok if i leave them on? oh and i just realized i didnt peel the master cylinder so another trip on sat will be in the making, here are some pics
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
nope, not going to work. you dont have enough parts.
you need these...
http://i59.photobucket.com/albums/g3...s/axles007.jpg
you need these...
