silly me, help with valve adjust?
Alright, now I have done LOTS of reading and searching through many different forums to find the answer to properly adjusting my valves.
I've been having some serious issues with my car lately: passing smog, performance etc etc.
After not passing smog 2 times in a row, and it actually getting worse the second time I went through, I am attempting to pinpoint the problem. I have never done a valve adjustment, and dont think that my Grandma had it done to the car in a long time.
THUS, I am going to try and adjust the valves to see if this fixes some of my issues.
My car is an 86 GT 5.0. It is all stock from what I know, after asking my uncles if they did any mods to it etc and they all believe that it is stock. SO, now that I am present with a stock HO engine can someone provide some information or link to proper valve adjustment to acquire zero lash?
I have read a few things but some contradict each other. I trust alot of your advice here from the many of you who seem like gurus and I am in need.
I appreciate your help. Please let me know if I must provide additional info about the car etc.
Gracias
Gracias
if it is all stock even down to the stock pedastal mount rockers, valve adjustment is NOT your problem, lash is adjusted hydraulicaly , hence hydraulic roller cam......................what is your car failing for?? H/C, NOX, CO, CO2...???? HOW MANY MILES ON THE CAR??? if you attempt to adjust a non adjustable valvetrain, you are wasting your time as well as misinformed!! and you will not fix the problem.
It failed HC. the first time as 500 hc, the second time after new cats installed, egr etc etc it failed with 2000 hc at idle!
The smog tech was saying that I have a dead cylinder, but they all fire. I tested this by pulling off a spark plug line and seeing how the engine replies. I did this with all cylinders and when the plug comes off at the dizzy it stumbles slightly. I've done a compression test and they were all around the same number, though I dont remember exactly what it was.
I'm wondering if perhaps the injectors are too high of a flow rate, thus causing excessive HC?
Car has 70k original miles
Now my question as I thought about it reading your post, what if some of the rockers are loose? Can no adjustment be made to my setup? I understand that there needs to be zero lash, but can I not bring the rockers into zero lash by manual adjustment?
http://www.smogtips.com/failed-high-hydrocarbons-HC.cfm
I've read that website before. Lots of good stuff on there. Thanks for reposting it again for me.
Thats actually my next step. I've got new plugs, wires and all the ignition components that are easily damaged/worn out to install.
What is a good gap for stock copper motorcraft plugs? The motorcraft information says .050 but that seems a bit too large...Would having different sized gaps contribute to higher HC's/unburned fuel?
Muchas gracias for your help
I wish there were some local california guys around who could me out......
mungodrums
09-28-2015 10:54 PM
