Water leak from the lower intake?
Old 04-19-2012, 02:54 PM
Danielsmustang
Danielsmustang's Avatar
Default Water leak from the lower intake?
Hey whatsup guys, new to the 5.0 section. I got a 1991 hatch. I got the car after it being out of comission for years, It runs really good, i did a complete tune up and its running like a solid 5.0. But now i have a issue. Whenever i seem to put stress on the engine, i get a huge water leak. i dont know from where but its like a peehole size hole splurting out high pressure water. As the engine cools down, the pressure also does. Now What do you guys think? The car is not overheating. Unless my gauge is messed up. But i dont think so. Any opinions?
Danielsmustang is offline
Old 04-19-2012, 03:12 PM
mattdel
mattdel's Avatar
There's a coolant hose that runs down to the back of the lower intake, behind the throttle body area. It's a bitch to get to, but they're known for popping pin holes.
mattdel is offline
Old 04-19-2012, 03:13 PM
Danielsmustang
Im sorry i Forgot to mention where its coming from. Its coming from from the back of the engine. It seems like by the heads, or lower intake or that plug that goes around that areo. Not quite Sure.. And its only when i push the engine. If i drive it normally, then its fine. And when i was driving it earlier, i was parking up and i heard somewhat of a vacuum leak. So i popped the hood and around that spot it was just throwing out steam. And the coolant reservoir was empty and when i opened the radiator ( engine was hot -.- ) it still had water.
Old 04-19-2012, 03:15 PM
Danielsmustang
Hmmm, see that sounds probable. Its like a pin hole size water leak. Im guessing i would have to jack up the engine a but to get to it.
Old 04-19-2012, 03:57 PM
Tony71502
Tony71502's Avatar
Shouldn't have to jack up the engine to get to any coolant lines.
Tony71502 is offline
2007CalSpec
12-13-2020 11:42 AM
Nick Oliver
10-17-2018 04:22 AM
Pyrate Dave
09-10-2015 07:30 PM
Luke9222
09-04-2015 06:46 AM
Quick Reply: Water leak from the lower intake?
