Is My TPS Bad?
Old 06-14-2012, 05:11 PM
AAX86
AAX86's Avatar
Default Is My TPS Bad?
I got KOEO code 23 "tps signal out of range". Tried messing with the tps. It was at 1.93v when i first tested it. The highest reading i got was 2.04v and the lowest i could get it to was 1.75v +/-
All tested at closed throttle. Is it time to buy a new tps? If so, how much will it run me?
AAX86 is offline
Old 06-14-2012, 05:32 PM
mattdel
mattdel's Avatar
Yes, and about $20.
mattdel is offline
Old 06-14-2012, 06:38 PM
AAX86
AAX86's Avatar
Thank you
AAX86 is offline
Old 06-14-2012, 07:45 PM
stangman33
stangman33's Avatar
whats the voltage supposed to be?
stangman33 is offline
Old 06-15-2012, 12:35 AM
mattdel
mattdel's Avatar
Most vehicles, @ idle(closed throttle), anywhere from 0.4v to 0.9v
As long as the full sweep from idle to WOT is nearly exactly 4 volts, it doesn't matter much, but it can't be over 1.0 @ idle otherwise you'll pop a code, because the input voltage is 5v, so if you start over 0.9v, at WOT you'll be maxed out on voltage and the ECM won't be able to figure out the correct fuel compensation.
mattdel is offline
Old 06-15-2012, 02:23 PM
AAX86
AAX86's Avatar
Got a new TPS. Didn't check voltage cause i don't want holes in my wires but it cleared the code so i guess it's okay.
AAX86 is offline
Dathan
10-05-2015 05:52 AM
KingRando
10-02-2015 08:06 AM
ChampInSD
10-02-2015 04:55 AM
UrS4
09-30-2015 10:13 AM
GLOCKer
09-28-2015 07:36 AM
Quick Reply: Is My TPS Bad?
