94 5.0 stall problem
Old 06-26-2012, 07:10 PM
  #31
Xsentric
Xsentric's Avatar
smoother shift into gears everything better
Xsentric is offline
Old 06-26-2012, 07:11 PM
  #32
Xsentric
Xsentric's Avatar
will try highway tomorrow
Xsentric is offline
Old 06-26-2012, 08:01 PM
  #33
mattdel
mattdel's Avatar
mattdel is offline
Old 06-26-2012, 09:43 PM
  #34
craig71springsport
craig71springsport's Avatar
Could be vacuum, could be several things.
electrical or fuel delivery for the stalling. The throttle staying open after you rev it sounds like possible throttle body or throttle cable issue to me. WD-40 your throttle linkage and the throttle flange inside the throttle body. Press the gas several times when it's off, then let it sit for a little. That'll give the WD-40 time to work it's magic. If that doesn't fix it, vacuum is a likely culprit.
IF YOU WANT THE EASY WAY OUT OF VACUUM SYSTEM TROUBLESHOOTING:
Go to a garage and see if they have a smoke machine for vacuum systems. They basically plug into the vacuum system and pump smoke into it. Anything that isn't sealed properly/damage will, obviously, leak smoke. It's going to cost some money, but in my opinion, it's MUCH better than having to do it yourself.
craig71springsport is offline
Old 06-27-2012, 12:55 AM
  #35
Xsentric
Xsentric's Avatar
ya im guessing its alot of vac stuff. my speedo started acting funny today. gunna call for dealer n see what a price for it might be
Xsentric is offline
Old 06-28-2012, 11:39 PM
  #36
Xsentric
Xsentric's Avatar
took off passenger inner wheel well found a really bad vac. line one of the bigger black ones. do i really need to pull fender off? its hard to get at the stuff in there..
Xsentric is offline
Old 06-28-2012, 11:42 PM
  #37
Xsentric
Xsentric's Avatar
i live in newhamshire i'd really like to get ride of smog stuff... and i no i can here.. how would i do that?
Xsentric is offline
Granatelli Sales
03-25-2016 08:01 PM
Granatelli Sales
12-27-2015 06:28 PM
TfcCDR
09-14-2015 12:08 PM
Ryan Fitzpatrick
09-14-2015 02:21 AM
5.0 kevo
09-03-2015 06:24 PM
Quick Reply: 94 5.0 stall problem
