Solid motor mounts
Old 07-11-2012, 09:50 AM
FoRdBoY357
FoRdBoY357's Avatar
Default Solid motor mounts
Does anyone have any specs/drawings/measurements for some solid 5.0 motor mounts for a 94/95 GT? I work in a fab shop but I have nothing to base a mount off of.
FoRdBoY357 is offline
Old 07-11-2012, 10:27 AM
Tony71502
Tony71502's Avatar
Why do you want solid mounts? Use a regular engine mount and base it off of that.
Tony71502 is offline
Old 07-11-2012, 10:32 AM
dawson1112
dawson1112's Avatar
I agree why have solid mounts on it. The engine needs to have a way to flex and move other wise your gonna be breaking welds or bolts or worse cross member.
Engines vibrate and believe me if they were solid mounts youd feel it through the whole car till something gives
dawson1112 is offline
Old 07-11-2012, 10:40 AM
dawson1112
dawson1112's Avatar
Ok I understand why you would want solid mounts for reaction time I know pple have used them for a long time at the track to get more power to the ground quicker. I just wouldnt want them . But you should be able to get a stock mount and go off that i you want the solids . Just remember to beef up the trans mounts or youll be busting the bell housing
Old 07-11-2012, 10:58 AM
javila2468
javila2468's Avatar
I know you didn't ask for an opinion but how about you get som Prothane Motor Mounts and make a Solid Tranmission Mount?
if you are going with solid motor mounts make sure to use prothane transmission mount.
solid motor = poly tranyy
poly motor = solid tranny
solid motor + solid tranny = disaster sooner or later
javila2468 is offline
Old 07-11-2012, 11:28 AM
Tony71502
Tony71502's Avatar
Prothane mounts raise the engine up 3/4"-1". Just FYI. So do most aftermarket solids. If you copy the oem mounts, dimension wise, then your engine will stay in the proper place. Solid trans mounts are meant to be run with solid motor mounts.
Here's a quote from a website that sells them, they are also a sponser of this site:
"Solid Transmission Mounts must be used in conjunction with Solid Motor Mounts to prevent breakage of engine block and transmission case due to torsional stress."
Old 07-11-2012, 11:50 AM
javila2468
javila2468's Avatar
I guess there is alot of contraversy out on the internet. I've always read this:
I guess its time to change my search engine. lol. now i understand why you would need to install solid motor mounts with solid tranmission mount.
Old 07-11-2012, 12:56 PM
Tony71502
Tony71502's Avatar
I'm using Prothane poly motor mounts and the stock rubber trans mount. Works great except the poly mounts lifted my engine up about 3/4".
Old 07-11-2012, 10:11 PM
mjr46
D.R. THE PATHETIC DORK
mjr46's Avatar
think about it, if the front of the motor can move/twist and the back can't , what and where must give??? yup.....usually crack a bellhousing , got a few friends who have done it
mjr46 is offline
Old 07-12-2012, 09:51 AM
FoRdBoY357
FoRdBoY357's Avatar
Well I definitely don't want to raise the motor up any. Lower would be best.
jwog666
12-27-2021 08:09 PM
baddog671
07-26-2016 01:20 PM
UrS4
10-03-2015 06:23 AM
Explosive
10-02-2015 07:45 AM
logan409
09-26-2015 07:43 PM
Quick Reply: Solid motor mounts
