Base Pan gasket replacement
I've did it in my 95. It's a giant pain in the ***! You have to unbolt the rack & pinion, uncouple the steering shaft, Remove motor mount nuts & jack up the motor just to clear the K-member. I'd just pay the $400 bucks if I ever have to do it again.
Ehh, I'd rather spend a few hours of my time for FREE than spend $400. I had to unbolt the engine mounts, tranny mount, and then put my engine lift on and raise the whole drivetrain(engine and transmission) up. I also removed the driveshaft.
My oil pan drain plug was stripped and I didn't know it until I went to change the oil for the first time.
It's not hard if you know what you are doing.
mungodrums
Suspension
09-07-2015 07:22 PM
